[ Feature Request ] Better upload on mobile client
Being a long time seafile user, I wanted to point something to improve in the mobile client : upload.
Actual behavior :
  • You select multiple files to upload to a seafile folder
  • Or, you select a big file like phone camera videos to upload
  • Often, upload notification popup (in android notification bar) will not show at all
  • Often, you cannot follow efficiently the progress
  • Performance, seems to also be very bad (slow on 5G in big city, which is kind of weird. It might be upload datarate, but I wonder if it’s not a problem on seafile android client. I should test on wifi to remove any doubt.)
  • Seafile doesn’t tell you if it worked on not. It’s your guess, you go to the desired folder and see if your files have been uploaded. And if you had multiple which you don’t know by name… good luck !
Optimal behavior (Feature Request) :
  • Something like an uploading screen which allows you to follow progress file by file, like you see on web desktop pop-in, and marks if there was a problem with a file.
  • Error or warning messages if it didn’t work.
  • And why not the possibility to pause/resume transfer, or to cancel some files.
I’m curious, anyone else here feeling like this is not polished yet, and a possible feature for next versions of seafile ?
