How do I force delete trash?
I have Seafile installed on my Linux box and 3 libraries of roughly 100gb and I cant wait 30 days for it be deleted.
Please Advise.
You could log into the web interface, and set the retention time for the library to a shorter history, or no history. After that run the garbage collection, and then you can switch back to the 30 days, or whatever you would like.
Of course, forgot about that. Thanks
Will try it again once I manually upgrade Portainer which appears to have a console issue at the moment.
