I think I have found some bugs in seafile 12.06. I will post them as separate topics to keep things from getting confused. First some background; I am not familiar with docker, so I did some test deployments as a new install to get a sense of how things are supposed to work. Then I tried to clone existing seafile server (version 11.0.13, not docker) and upgrade the clone to the new version 12 docker.
I plan to make a post with my complete upgrade process later because it might help other people, so if you need additional information, I can reproduce these bugs to get more logs or whatever.
First bug-
The permissions are not set correctly on the log directory when it is created, causing failures to start the seafile service. This happens when using NON_ROOT=true. Here is the log:
seafile | *** Running /etc/my_init.d/01_create_data_links.sh...
seafile | *** Booting runit daemon...
seafile | *** Runit started as PID 14
seafile | *** Running /scripts/enterpoint.sh...
seafile | 2024-12-23 04:19:58 Nginx ready
seafile | 2024-12-23 04:19:58 Create linux user seafile in container, please wait.
seafile | 2024-12-23 04:26:31 This is an idle script (infinite loop) to keep container running.
seafile | [2024-12-23 04:26:32] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.
seafile | [2024-12-23 04:26:32] Running scripts /opt/seafile/seafile-server-12.0.6/upgrade/upgrade_11.0_12.0.sh
seafile | [12/23/2024 04:26:32][upgrade]: Running script /opt/seafile/seafile-server-12.0.6/upgrade/upgrade_11.0_12.0.sh
seafile |
seafile | -------------------------------------------------------------
seafile | This script would upgrade your seafile server from 11.0 to 12.0
seafile | Press [ENTER] to contiune
seafile |
seafile |
seafile | Updating seafile/seahub database ...
seafile |
seafile | [INFO] You are using MySQL
seafile | [INFO] updating seafile database...
seafile | [INFO] updating seahub database...
seafile | [INFO] updating seafevents database...
seafile | Done
seafile |
seafile | migrating avatars ...
seafile |
seafile | Done
seafile |
seafile | updating /opt/seafile/seafile-server-latest symbolic link to /opt/seafile/seafile-server-12.0.6 ...
seafile |
seafile |
seafile |
seafile | -----------------------------------------------------------------
seafile | Upgraded your seafile server successfully.
seafile |
seafile |
seafile | Starting seafile server, please wait ...
seafile | /opt/seafile/seafile-server-12.0.6/seafile.sh: line 178: /opt/seafile/logs/seafile-monitor.log: Permission denied
seafile | Failed to start seafile server
seafile | File "/scripts/start.py", line 94, in <module>
seafile | main()
seafile | File "/scripts/start.py", line 76, in main
seafile | call('su seafile -c "{} start"'.format(get_script('seafile.sh')))
seafile | File "/scripts/utils.py", line 70, in call
seafile | return subprocess.check_call(*a, **kw)
seafile | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
seafile | File "/usr/lib/python3.12/subprocess.py", line 413, in check_call
seafile | raise CalledProcessError(retcode, cmd)
seafile | subprocess.CalledProcessError: Command 'su seafile -c "/opt/seafile/seafile-server-12.0.6/seafile.sh start"' returned non-zero exit status 1.
The /shared/seafile/logs directory is created without giving the seafile user permission to write to it. To work around I did ‘find -type d -exec chmod 777 “{}” ;’, then docker-compose down, and docker-compose up again.
