I’m trying to setup seafile through docker. After the first startup, I open the web login page, but when I try to signin with the admin credential (provided to SEAFILE_ADMIN_EMAIL and SEAFILE_ADMIN_PASSWORD), it fails with an error message Incorrect email or password. There is no network issue though (all 200 even /accounts/login/ request responds with 200). So it’s quite confusing.
Inspecting seafile container’s logs, this seems to be related
Error happened during creating seafile admin.
compose.yml:
seafile:
container_name: seafile
restart: unless-stopped
SEAFILE_ADMIN_EMAIL: me@mail.com
SEAFILE_ADMIN_PASSWORD: admin
DB_HOST: seafile-db
DB_ROOT_PASSWD: mysql
SEAFILE_SERVER_LETSENCRYPT: false
- "12345:80"
- /box/seafile:/shared
depends_on:
- seafile-db
- memcached
networks:
- seafile
memcached:
image: memcached:alpine
entrypoint: memcached -m 256
networks:
- seafile
seafile-db:
image: mysql:latest
container_name: seafile-db
restart: always
MYSQL_ROOT_PASSWORD: mysql
- seafile-db:/var/lib/mysql
networks:
- seafile
seafile-db:
networks:
seafile:
When I try to run myself reset-admin.sh script from inside the container it also fails
$ docker exec -it seafile /opt/seafile/seafile-server-latest/reset-admin.sh
E-mail address: test@test.io
Password:
Password (again):
File "/opt/seafile/seafile-server-10.0.1/seahub/manage.py", line 10, in <module>
File "/opt/seafile/seafile-server-10.0.1/seahub/thirdpart/django/core/management/__init__.py", line 419, in execute_from_command_line
utility.execute()
File "/opt/seafile/seafile-server-10.0.1/seahub/thirdpart/django/core/management/__init__.py", line 413, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/opt/seafile/seafile-server-10.0.1/seahub/thirdpart/django/core/management/base.py", line 354, in run_from_argv
self.execute(*args, **cmd_options)
File "/opt/seafile/seafile-server-10.0.1/seahub/thirdpart/django/core/management/base.py", line 398, in execute
output = self.handle(*args, **options)
File "/opt/seafile/seafile-server-10.0.1/seahub/seahub/base/management/commands/createsuperuser.py", line 150, in handle
User.objects.create_superuser(email, password)
File "/opt/seafile/seafile-server-10.0.1/seahub/seahub/base/accounts.py", line 71, in create_superuser
u = self.create_user(email, password, is_staff=True, is_active=True)
File "/opt/seafile/seafile-server-10.0.1/seahub/seahub/base/accounts.py", line 61, in create_user
return self.get(email=email)
File "/opt/seafile/seafile-server-10.0.1/seahub/seahub/base/accounts.py", line 99, in get
raise User.DoesNotExist('User matching query does not exits.')
seahub.base.accounts.DoesNotExist: User matching query does not exits.
Am I missing something? Does anyone have a working seafile deployed using latest docker images?
inspecting the mysql database (inside the db container)
mysql> select user,host from user;
| user | host |
| root | % |
| seafile | %.%.%.% | // what is this host ???
| mysql.infoschema | localhost |
| mysql.session | localhost |
| mysql.sys | localhost |
| root | localhost |
6 rows in set (0.00 sec)
