Hallo liebe Leute ich bin am verzweifeln .
gibte es eine docker-compose.yml die Funktioniert.
Ich habe zahlreiche probiert manche gehen kurzeitig manche gar nicht.
Wenn die Pro Version auch so ist dann Danke.
Hallo
Did get me some time to figure this out as well but I have it in production with storage on s3 and did a lot of googling on it.
I have seafile-pro running on ubuntu 18 and a 8GB memory VPS together with traefik.
With Installing libreoffice or collabora on the same server I had problems and had to install a another vps with it. (install is not described here)
You should have a dns directing to your server.
properly installed docker/docker-compose and firewall
(see digitalocean.com with nice installation procedures for it on ubuntu 18)
Hopefully you get it working. (be ware of using latest as a tag as it may corrupt your setup)
(you can reply in german)
mfg/regards
stephan
Steps are:
sudo -i
mkdir seafile
cd seafile
docker login docker.seadrive.org (passwd in customercenter)
docker network create --driver bridge --attachable --subnet=172.25.0.0/24 --gateway=172.25.0.10 seafile-net
Replace every value <…> with your own value in the files below.
docker-compose -f docker-compose-traefik.yml up -d
docker-compose -f docker-compose-seafile.yml up -d
FILES: beware that unfortunately the indentation is lost.
version: ‘3’
db:
image: mariadb:10.1
container_name: seafile-mysql
restart: unless-stopped
- MYSQL_ROOT_PASSWORD=
- MYSQL_LOG_CONSOLE=true
- ./seafile-mysql/db:/var/lib/mysql
networks:
seafile-net:
ipv4_address: 172.25.0.3
memcached:
image: memcached:latest
entrypoint: memcached -m 256
- “11211:11211”
networks:
seafile-net:
ipv4_address: 172.25.0.4
command: [“memcached -m 256”]
elasticsearch: # not needed
image: seafileltd/elasticsearch-with-ik:5.6.16
- discovery.type=single-node
- bootstrap.memory_lock=true
- “ES_JAVA_OPTS=-Xms1g -Xmx1g”
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 2g
- ./seafile-elasticsearch_data:/usr/share/elasticsearch/data # specifies the path to Elasticsearch data persistent store.
networks:
- seafile-net
seafile:
image: docker.seadrive.org/seafileltd/seafile-pro-mc:7.1.7
image: docker.seadrive.org/seafileltd/seafile-pro-mc:latest
- “7080:80”
- /etc/localtime:/etc/localtime:ro
- ./seafile-data:/shared # Requested, specifies the path to Seafile data persistent store.
- DB_HOST=db
- DB_ROOT_PASSWD= # Requested, the value shuold be root’s password of MySQL service.
- TIME_ZONE=Europe/Amsterdam # Optional, default is UTC. Should be uncomment and set to your local time zone.
- SEAFILE_ADMIN_EMAIL= # Specifies Seafile admin user default is ‘me@example.com’
- SEAFILE_ADMIN_PASSWORD= # Specifies Seafile admin password, default is ‘asecret’.
- SEAFILE_DB_USER=seafile
- SEAFILE_SERVER_HOSTNAME=<xxxxx.yyyyyyy.zz> # Specifies your host name if https is enabled.
- SEAFILE_SERVER_URL=https://<xxxxx.yyyyyy.zz> # Specifies your host name if https is enabled.
- SEAFILE_SERVICE_URL=https:<//<xxxxx.yyyyyy.zz> # Specifies your host name if https is enabled.
- SEAFILE_FILE_SERVER_ROOT=https://<xxxxx.yyyyy.zz>/seafhttp
labels:
- “traefik.enable=true”
- “traefik.http.routers.seafile.entrypoints=http”
- “traefik.http.routers.seafile.rule=Host(<xxxxx.yyyyy.zz>)”
- “traefik.http.middlewares.seafile-https-redirect.redirectscheme.scheme=https”
- “traefik.http.routers.seafile.middlewares=seafile-https-redirect”
- “traefik.http.routers.seafile-secure.entrypoints=https”
- “traefik.http.routers.seafile-secure.rule=Host(<xxxxx.yyyyy.zz>)”
- “traefik.http.routers.seafile-secure.tls=true”
- “traefik.http.routers.seafile-secure.tls.certresolver=http”
- “traefik.http.routers.seafile-secure.service=seafile”
- “traefik.http.services.seafile.loadbalancer.server.port=80”
- “traefik.docker.network=seafile-net”
- “traefik.http.routers.seafile-secure.middlewares=seafile-dav,secHeaders@file”
- “traefik.http.middlewares.seafile-dav.replacepathregex.regex=^/.well-known/ca(l|rd)dav”
- “traefik.http.middlewares.seafile-dav.replacepathregex.replacement=/remote.php/dav/”
depends_on:
- db
- memcached
extra_hosts:
- “<xxxxx.yyyyy.zz>:172.25.0.5”
dns: 8.8.8.8
networks:
seafile-net:
ipv4_address: 172.25.0.5
networks:
seafile-net:
external: true
version: ‘3’
traefik:
image: traefik:latest
container_name: traefik
command:
- “–log.level=DEBUG”
- “–providers.docker=true”
- --providers.docker=true
- --api
security_opt:
- no-new-privileges:true
- “80:80”
- “8080:8080”
- “443:443”
- /var/run/docker.sock:/var/run/docker.sock
- ./traefik-data/traefik.yml:/traefik.yml
- ./traefik-data/acme.json:/acme.json
- ./traefik-data/dynamic_conf.yml:/dynamic_conf.yml
labels:
- “traefik.http.routers.traefik.entrypoints=http”
- “traefik.http.routers.traefik.rule=Host(traefik.<yyyyy.zz>)”
- “traefik.http.middlewares.traefik-auth.basicauth.users=admin:”
- “traefik.http.middlewares.traefik-https-redirect.redirectscheme.scheme=https”
- “traefik.http.routers.traefik.middlewares=traefik-https-redirect”
- “traefik.http.routers.traefik-secure.entrypoints=https”
- “traefik.http.routers.traefik-secure.rule=Host(traefik.<yyyyyy.zz>)”
- “traefik.http.routers.traefik-secure.middlewares=traefik-auth,secHeaders@file”
- “traefik.http.routers.traefik-secure.tls=true”
- “traefik.http.routers.traefik-secure.tls.certresolver=http”
- “traefik.http.routers.traefik-secure.service=api@internal”
- “providers.file.filename=/dynamic_conf.yml”
networks:
seafile-net:
ipv4_address: 172.25.0.11
tls:
options:
default:
minVersion: VersionTLS12
cipherSuites:
- TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
- TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
- TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305
- TLS_AES_128_GCM_SHA256
- TLS_AES_256_GCM_SHA384
- TLS_CHACHA20_POLY1305_SHA256
curvePreferences:
- CurveP521
- CurveP384
sniStrict: true
http:
middlewares:
secHeaders:
headers:
browserXssFilter: true
contentTypeNosniff: true
frameDeny: true
sslRedirect: true
#HSTS Configuration
stsIncludeSubdomains: true
stsPreload: true
stsSeconds: 31536000
customFrameOptionsValue: “SAMEORIGIN”
api:
dashboard: true
entryPoints:
http:
address: “:80”
https:
address: “:443”
providers:
docker:
endpoint: “unix:///var/run/docker.sock”
exposedByDefault: false
file:
filename: “/dynamic_conf.yml”
certificatesResolvers:
http:
acme:
email:
storage: acme.json
httpChallenge:
entryPoint: http
Danke für die Antwort
Ich habe meinen Server zuhause ein 8 Kerner mit 12GB Ram
Ich brauche nicht die Pro Version die kann ich mir nicht leisten.
Mfg Wolfgang
up to 3 usrs it is free
i use a very similar docker-compose.yml file. But I always get the following error message in the Docker Logs:
*** Booting runit daemon...
*** Runit started as PID 15
*** Running /scripts/start.py...
Checking python on this machine ...
Cecking for java ...Done.
verifying password of user root ... done
[2020-11-02 13:45:48] Now running setup-seafile-mysql.py in auto mode.
verifying password of user seafile ...
Failed to connect to mysql server using user "seafile" and password "***": Access denied for user 'seafile'@'172.17.0.7' (using password: YES)
Just like in your docker-compose file I only set the MYSQL_ROOT_PASSWORD the DB_ROOT Password and SEAFILE_DB_USER=seafile
How can I fix this error? Unfortunately I have not found anything on Google. Did you ever had this error?
Dear Niklas
I guess it is related to a not completed install of the mysql database.
Get in to docker mysql by:
docker exec -it seafile-mysql /bin/bash
than execute: mysql -uroot -p and check with use show databases; and use seafile_db show tables if all tables exist.
If that is ok than maybe there is an issue with rights.
to check:
use mysql; select * from user; /
result should be host %.%.%.% for user seafile
and check if you get in by mysql -u’seafile’@‘172.17.0.7’ -p
If not google to get these permission right.
Otherwise I need your full *yml file without secret details
Good luck
