``.gitignore``-like negation patterns not implemented for ``seafile-ignore.txt``
I’d like to request the addition of negation patterns to the seafile-ignore.txt syntax.
The negation patterns can allow a user to not ignore a path that was previously marked as ignored (effectively whitelisting it).
Example: Let’s say you want to only sync files app1/config.xml and app1/app.exe to a seafile library, but app1/ can contain an arbitrary amount of unwanted files generated by app1/app.exe on runtime, with exclusion patterns you could solve this problem by adding this to seafile-ignore.txt on that library:
app1/*
!app1/config.xml
!app1/app.exe
This could be achieved by creating symbolic links from /home/user/app1/config.xml and /home/user/app1/app.exe to app1/ and then running /home/user/app1/app.exe from there. Sadly for Windows users, Seafile desktop does not read symbolic links to files correctly, making that impossible.
Hey Seafile Team,
Are there any plans to implement this?
This is the feature I’m missing to replace my last syncthing folder with seafile. I want to sync specific application config files in my mac’s ~/Library/Application Support folder, without negated ignore patterns I’m going to have to make one library per application.
