So I am setting up a seafile instance on my homelab, but the provided defaults do not work with my existing setup. I had to convert the Docker compose files to Podman Quadlet files since my server uses rootless Podman rather than Docker. Here’s my environment file for Seafile:
seafile-server.env
DB_HOST=localhost
DB_PORT=3306
DB_USER=seafile
DB_ROOT_PASSWD=${redacted}
DB_PASSWORD=${redacted}
TIME_ZONE=America/Chicago
INIT_SEAFILE_ADMIN_EMAIL=${redacted}
INIT_SEAFILE_ADMIN_PASSWORD=${redacted}
SEAFILE_SERVER_HOSTNAME=cloud.linuxdragon.dev
SEAFILE_SERVER_PROTOCOL=http
SITE_ROOT=/
NON_ROOT=false
JWT_PRIVATE_KEY=${redacted}
SEAFILE_LOG_TO_STDOUT=true
ENABLE_SEADOC=true
SEADOC_SERVER_URL=https://cloud.linuxdragon.dev/sdoc-server
I share this because I there is a possibility that I’ve misconfigured Seafile itself…
The issue, then, is that when I try to navigate to Seafile, I get a 400 Bad Request status code, with a slightly more helpful message of Contradictory Scheme headers. So the most likely culprit is the Nginx reverse proxy I run on another machine.
81-cloud.linuxdragon.dev.conf
# vim: filetype=nginx
# HTTPS PORT 443 CONFIGURATION
server_name cloud.linuxdragon.dev;
listen [::]:443 ssl;
listen 443 ssl;
http2 on;
proxy_pass http://homelab:1080;
include /etc/nginx/headers.conf.d/5-reverse_proxy-headers.conf;
include /etc/nginx/headers.conf.d/0-security-headers.conf;
include /etc/nginx/headers.conf.d/4-container-headers.conf;
proxy_read_timeout 310s;
include /etc/nginx/ssl.conf.d/0-options-ssl.conf;
include /etc/nginx/ssl.conf.d/3-linuxdragon.dev-ssl.conf;
# HTTP PORT 80 CONFIGURATION
if ($host = cloud.linuxdragon.dev) {
listen 80;
listen [::]:80;
return 404;
I have a very manageable and replicable system in place already, which is why I do not need or want to use Caddy. When I want to spin up another service on my homelab, I literally add the subdomain to the cert (since I don’t use wildcards for SSL) with Certbot, and copy the nginx configuration file from another service. All I have to change is the name of the new configuration file, the server_name config option, and the port in the proxy_pass config option (homelab is mapped via this system’s /etc/hosts file). Here are the files referenced by the include directive above.
proxy_http_version 1.1;
proxy_set_header Connection "Upgrade";
proxy_set_header X-Forwarded-Protocol $scheme;
proxy_redirect off;
# Security Headers
add_header X-XSS_Protection 0;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains; preload";
add_header X-Content-Type-Options "nosniff";
add_header Referrer-Policy "no-referrer";
add_header Permissions-Policy "geolocation=(),midi=(),sync-xhr=(),microphone=(),camera=(),magnetometer=(),gyroscope=(),fullscreen=(self),payment=()";
#vim: filetype=nginx
add_header X-Frame-Options "SAMEORIGIN";
add_header Content-Security-Policy "default-src 'none'; base-uri 'self'; form-action 'self'; frame-src 'self'; frame-ancestors 'self'; script-src 'self' blob: 'unsafe-inline' 'unsafe-eval'; style-src 'self' 'unsafe-inline' https://fonts.codedragon.dev; font-src 'self' data: *; manifest-src 'self' data: *; img-src 'self' data: *; connect-src 'self' wss:;";
add_header X-Robots-Tag "noindex, noarchive, nofollow";
# SSL Certificates Paths
ssl_certificate /etc/letsencrypt/live/linuxdragon.dev/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/linuxdragon.dev/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/live/linuxdragon.dev/chain.pem;
0-options-ssl.conf
# Enable session resumption to improve https performance
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
# Set the ssl server cipher preferences
ssl_protocols TLSv1.2 TLSv1.3;
ssl_prefer_server_ciphers on;
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384";
#OCSP Stapling
# ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
# ssl_stapling on;
# ssl_stapling_verify on;
