Is there anyone that successfully got seafile working with traefik proxy in docker ? I can access seafile remotely when using labels but I can not upload anything or view anything in the label.
Below are the labels I used, any help would be great. this will be the first time I tried to get traefik to work that involves more than one port
traefik.enable=true
traefik.http.routers.seafile.rule=Host(seafile.example.com)
traefik.http.services.seafile.loadbalancer.server.port=8000
traefik.http.routers.seafile.service=seafile
this needs to turn in to http://:8082:/files/xxx/xxx/xx
traefik.http.routers.seafhttp.rule=Host(seafile.example.com) && PathPrefix(/seafhttp)
traefik.http.services.seafhttp.loadbalancer.server.port=8082
traefik.http.routers.seafhttp.service=seafhttp
traefik.http.middlewares.sf-replacepath.replacepathregex.regex=^/seafhttp/(.*)
traefik.http.middlewares.sf-replacepath.replacepathregex.replacement=/$$1
traefik.http.routers.seafhttp.middlewares=sf-replacepath
the above worked with port 80.
#added the below to use HTTPS
to tell traefik to try get a letsencrypt cert for your domain
traefik.http.routers.seafile.tls.certresolver=letsencrypt
#[1]If you want to redirect port 80 to 443 when connecting to this domain on port 80
traefik.http.middlewares.https-redirect.redirectscheme.scheme=https
traefik.http.routers.https-redirect.entrypoints=web
traefik.http.routers.https-redirect.middlewares=https-redirect
traefik.http.routers.https-redirect.rule=Host(seafile.example.com)
hobbsAU
February 19, 2021, 6:58am
Yes, the following traefik v2 works.
Make sure you have an https entrypoint setup and working first (use a whoami container to test). I also completely disabled and removed nginx in the Seafile container, it is not needed.
The following docker-compose is compatible with Seafile 7 or 8 and will proxy:
Seafile (TCP/8000)
Seafhttp (TCP/8082)
SeafDav (TCP/8080)
seafile:
image: seafile:local
- ${VOLDIR}/seafile-data:/shared
- DB_HOST=seafile-db
- DB_ROOT_PASSWD=${SF_MYSQL_ROOTPWD}
- TIME_ZONE=${TZ}
- SEAFILE_ADMIN_EMAIL=${SF_ADMIN_EMAIL}
- SEAFILE_ADMIN_PASSWORD=${SF_ADMIN_PWD}
- SEAFILE_SERVER_HOSTNAME=${SF_FQDN}
- SEAFILE_SERVICE_URL=https://${SF_FQDN}
- SEAFILE_FILE_SERVER_ROOT=https://${SF_FQDN}/seafhttp
depends_on:
- seafile-db
- seafile-memcached
expose:
- 8000
- 8082
- 8080
networks:
- seafile-internal
- proxy-internal
labels:
- traefik.enable=true
# HTTP Router Seafile
- traefik.http.routers.seafile.rule=Host(`seafile.${DOMAINNAME}`)
- traefik.http.routers.seafile.entrypoints=https
- traefik.http.routers.seafile.tls=true
- traefik.http.routers.seafile-http.middlewares=sec-headers
- traefik.http.routers.seafile.service=seafile
- traefik.http.services.seafile.loadbalancer.server.port=8000
# HTTP Router Seafdav
- traefik.http.routers.seafile-dav.rule=Host(`seafile.${DOMAINNAME}`) && PathPrefix(`/seafdav`)
- traefik.http.routers.seafile-dav.entrypoints=https
- traefik.http.routers.seafile-dav.tls=true
- traefik.http.routers.seafile-dav.service=seafile-dav
- traefik.http.services.seafile-dav.loadbalancer.server.port=8080
# HTTP Router Seafhttp
- traefik.http.routers.seafile-http.rule=Host(`seafile.${DOMAINNAME}`) && PathPrefix(`/seafhttp`)
- traefik.http.routers.seafile-http.entrypoints=https
- traefik.http.routers.seafile-http.tls=true
- traefik.http.routers.seafile-http.middlewares=seafile-strip
- traefik.http.routers.seafile-http.service=seafile-http
- traefik.http.services.seafile-http.loadbalancer.server.port=8082
# Middlewares
- traefik.http.middlewares.seafile-strip.stripprefix.prefixes=/seafhttp
- traefik.http.middlewares.sec-headers.headers.framedeny=true
- traefik.http.middlewares.sec-headers.headers.sslredirect=true
- traefik.http.middlewares.sec-headers.headers.browserXssFilter=true
- traefik.http.middlewares.sec-headers.headers.contentTypeNosniff=true
- traefik.http.middlewares.sec-headers.headers.forceSTSHeader=true
- traefik.http.middlewares.sec-headers.headers.stsIncludeSubdomains=true
- traefik.http.middlewares.sec-headers.headers.stsPreload=true
- traefik.http.middlewares.sec-headers.headers.referrerPolicy=same-origin
# Network
- traefik.docker.network=traefik_proxy-internal
networks:
proxy-external:
proxy-internal:
#internal: true # commented out if containers need non-proxied outbound Internet access
seafile-internal:
internal: true
hobbsAU:
HTTP Router Seafile - traefik.http.routers.seafile.rule=Host(seafile.${DOMAINNAME}) - traefik.http.routers.seafile.entrypoints=https - traefik.http.routers.seafile.tls=true - traefik.http.routers.seafile-http.middlewares=sec-headers - traefik.http.routers.seafile.service=seafile - traefik.http.services.seafile.loadbalancer.server.port=8000 # HTTP Router Seafdav - traefik.http.routers.seafile-dav.rule=Host(seafile.${DOMAINNAME}) && PathPrefix(/seafdav) - traefik.http.routers.seafile-dav.entrypoints=https - traefik.http.routers.seafile-dav.tls=true - traefik.http.routers.seafile-dav.service=seafile-dav - traefik.http.services.seafile-dav.loadbalancer.server.port=8080 # HTTP Router Seafhttp - traefik.http.routers.seafile-http.rule=Host(seafile.${DOMAINNAME}) && PathPrefix(/seafhttp) - traefik.http.routers.seafile-http.entrypoints=https - traefik.http.routers.seafile-http.tls=true - traefik.http.routers.seafile-http.middlewares=seafile-strip - traefik.http.routers.seafile-http.service=seafile-http - traefik.http.services.seafile-http.loadbalancer.server.port=8082 # Middlewares - traefik.http.middlewares.seafile-strip.stripprefix.prefixes=/seafhttp - traefik.http.middlewares.sec-headers.headers.framedeny=true - traefik.http.middlewares.sec-headers.headers.sslredirect=true - traefik.http.middlewares.sec-headers.headers.browserXssFilter=true - traefik.http.middlewares.sec-headers.headers.contentTypeNosniff=true - traefik.http.middlewares.sec-headers.headers.forceSTSHeader=true - traefik.http.middlewares.sec-headers.headers.stsIncludeSubdomains=true - traefik.http.middlewares.sec-headers.headers.stsPreload=true - traefik.http.middlewares.sec-headers.headers.referrerPolicy=same-origin
How would I use the syntax for here
would it be
(seafile.domain.name)
or
exactly like you had it
(seafile.${DOMAIN.NAME})
This ${DOMAINNAME} refers to an environment variable.
You can either
a) change to a domain name literal seafile.yourdomain.com as you have described
b) define the environment variable ${DOMAINNAME} in your .env file (should be in the same directory as your docker-compose.yml) as follows:
$ echo "DOMAINNAME=yourdomain.com" >> .env
Here is the docker compose reference Variable Substitution
I had to make the following changes to make it work
since I am using UNRAID docker, I can’t set variables. I had to set it such as - ( seafile.domain.name ) and that worked fine
Then I had to change the lines to say websecure vs HTTPS
Once I added these below lines. I can get the login page to load and I can sign in, but I can’t upload anything or view files like PDFs in the browser correctly. I am not the best of getting traefik rules to work. I copied some rules from other container that worked for me. Below is the delta’s I added
- traefik.http.routers.seafile.tls.certresolver=letsencrypt
- traefik.http.middlewares.https-redirect.redirectscheme.scheme=https
- traefik.http.routers.https-redirect.entrypoints=web
- traefik.http.routers.https-redirect.middlewares=https-redirect
- traefik.http.routers.https-redirect.rule=Host(`seafile.somedomain.tech`)
Here is everything I added
- traefik.http.routers.seafile.rule=Host(`seafile.somedomain.tech`)
- traefik.http.routers.seafile.entrypoints=websecure
- traefik.http.routers.seafile-dav.rule=Host(`seafile.somedomain.tech`)&&PathPrefix(`/seafdav`)
- traefik.http.routers.seafile-dav.entrypoints=websecure
- traefik.http.routers.seafile-http.rule=Host(`seafile.somedomain.tech`)&&PathPrefix(`/seafhttp`)
- traefik.http.routers.seafile-http.entrypoints=websecure
# Middlewares
# Things I added
ok, now its fully working with the config I pasted up above.
Once I went into the sysadmin settings and updated the below, everything is worked as its suppose to !
SERVICE_URL - https://seafile.somedomain.tech:8000
and
FILE_SERVER_ROOT - https://seafile.somedomain.tech/seafhttp
I can’t thank you enough for posting the config and getting me the rest of the way there!
great contribution! Thanks
Dear,
this image (Seafile without an internal nginx) is no longer available. Is there an alternative available?
I do not like the complexity of Firewall → NGINX (Central) → NGINX (Seafile) → Seafile Docker.
Thanks, -MN
You can handle your own direction from your central NGINX instance, I do this with Traefik and it works as expected.
