I need to compile the Seafile Command Line Client for an older Ubuntu version but before I wanted to ask: Is Linux - Seafile Admin Manual still up to date?
I ask because it mentions “ccnet” in
To build Seafile client, you need first build libsearpc and ccnet, seafile.
and as far as I know “ccnet” is not used anymore (?).
Furthermore the advice
You can set
--enable-wsto no to disable notification server.
is somehow confusing. I use an enable option to disable something? Maybe you could provide an example?
