UPDATE
The manual for this HOW TO is available now:
https://manual.seafile.com/deploy/only_office.html
UPDATE
What the Seafile server manual (more or less) suggests:
https://seafile.domain.com
https://onlyoffice.domain.com
What I want to achieve:
https://seafile.domain.com/onlyofficeds
I don’t want to use another subdomain, it should run on a subfolder and not on an subdomain.
Onlyoffice docker image setup and exposed locally under port 88
docker run -i -t -d -p 88:80 onlyoffice/documentserver
As I understand it is not neccessary to mount/map any local folders to the docker image as everything that is beeing pushed there will be temporary and does not need saving.
Nginx config
listen 80;
server_name seafile.domain.com;
# Required for only office document server
"" $scheme;
"" $host;
default upgrade;
"" close;
listen 443 http2;
ssl on;
ssl_certificate /etc/ssl/cacert.pem; # path to your cacert.pem
ssl_certificate_key /etc/ssl/privkey.pem; # path to your privkey.pem
server_tokens off;
fastcgi_pass 127.0.0.1:8000;
fastcgi_param HTTPS on;
fastcgi_read_timeout 36000;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
root /home/user/haiwen/seafile-server-latest/seahub;
location /seafdav {
fastcgi_pass 127.0.0.1:8080;
location /onlyofficeds/ {
proxy_http_version 1.1;
ProxyPassReverse https://seafile.domain.com/onlyofficeds http://127.0.0.1:88/
client_max_body_size 100; # Limit Document size to 100MB
proxy_read_timeout 3600s;
proxy_connect_timeout 3600s;
Seafile config in seahub__settings.py :
ENABLE_ONLYOFFICE = True
VERIFY_ONLYOFFICE_CERTIFICATE = False
ONLYOFFICE_APIJS_URL = ‘https://seafile.domain.com/onlyofficeds/web-apps/apps/api/documents/api.js’
ONLYOFFICE_FILE_EXTENSION = (‘doc’, ‘docx’, ‘ppt’, ‘pptx’, ‘xls’, ‘xlsx’, ‘odt’, ‘fodt’, ‘odp’, ‘fodp’, ‘ods’, ‘fods’)
Hosting like this works fine, easy to setup. Can be setup via script within seconds to minutes, depending on bandwith available.
@daniel.pan
I will update the Seafile manual once I got this working right.
It should contain some hints how to deploy OnlyOffice locally rather then external.
Of course the minimum server requirements are higher in combination with Seafile than a stand alone server for each app. I will write the recommendation for this up in the manual as well.
