Hello everyone
Summary: I have on a laptop a dev-pro
library which I synchronize with my server. The path is wrong:
Is there a way to edit this path?
Details:
First, how this happened. I was moving from Dropbox to Seafile and copied my dev-pro
folder to D:\Seafile\dev
. Then, by mistake, I copied it again at some point - without realizing it. This another copy went to D:\Seafile\dev\dev-pro\dev-pro
I pointed my library, unfortunately, to D:\Seafile\dev\dev-pro\dev-pro
and did an initial synchronization.
But the work I was doing form that point on was saved in D:\Seafile\dev\dev-pro\
Some time after, I discovered the subfolder dev-pro
in the existing one and after some checks removed it. Again, all my work is in D:\Seafile\dev\dev-pro\
and it is fine there.
Today I opened for some reason the client on my laptop, to discover what is in the screenshot above: that I was actually not synching because the synch directory does not exist.
My question: Is there a a way to edit the path in the existing library? Or should I rather remove it and recreate, pointing to the correct directory?
