I’m following the instructions in the pkerling/seafile package for CentOS installation.
However, I get the following error when trying to install GUI:
root@localhost: yum install seafile-client-qt
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
- base: mirrors_usinternet_com
- extras: mirrors_usinternet_com
- updates: mirrors_usinternet_com
Resolving Dependencies
–> Running transaction check
—> Package seafile-client-qt.x86_64 0:6.2.4-1.el7 will be installed
–> Processing Dependency: libQt5WebKitWidgets.so.5(Qt_5)(64bit) for package: seafile-client-qt-6.2.4-1.el7.x86_64
–> Processing Dependency: libQt5WebKit.so.5()(64bit) for package: seafile-client-qt-6.2.4-1.el7.x86_64
–> Processing Dependency: libQt5WebKitWidgets.so.5()(64bit) for package: seafile-client-qt-6.2.4-1.el7.x86_64
–> Finished Dependency Resolution
Error: Package: seafile-client-qt-6.2.4-1.el7.x86_64 (copr:copr.fedorainfracloud:pkerling:seafile)
Requires: libQt5WebKit.so.5()(64bit)
Requires: libQt5WebKitWidgets.so.5(Qt_5)(64bit)
Requires: libQt5WebKitWidgets.so.5()(64bit)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Any help is appreciated.
