Issue docker compose
I’m trying to install seafile with a docker compose-file like this:
  db:
    image: mariadb:10.11
    container_name: seafile-mysql
      - MYSQL_ROOT_PASSWORD=xxx  # Requested, set the root's password of MySQL service.
      - MYSQL_LOG_CONSOLE=true
      - MARIADB_AUTO_UPGRADE=1
      - /opt/seafile-mysql/db:/var/lib/mysql  # Requested, specifies the path to MySQL data persistent store.
    networks:
      - seafile-net
    restart: unless-stopped
  memcached:
    image: memcached:1.6.18
    entrypoint: memcached -m 256
    networks:
      - seafile-net
  seafile:
      - "8070:80"
#     - "443:443"  # If https is enabled, cancel the comment.
      - /media/usbdrive2/Seafile-Daten/seafile-data:/shared   # Requested, specifies the path to Seafile data persistent store.
      - DB_HOST=db
      - DB_ROOT_PASSWD=xxx  # Requested, the value should be root's password of MySQL service.
      - TIME_ZONE=Etc/UTC  # Optional, default is UTC. Should be uncomment and set to your local time zone.
      - SEAFILE_ADMIN_EMAIL=xxæx.com # Specifies Seafile admin user, default is 'me@example.com'.
      - SEAFILE_ADMIN_PASSWORD=xxx     # Specifies Seafile admin password, default is 'asecret'.
      - SEAFILE_SERVER_LETSENCRYPT=false   # Whether to use https or not.
      - SEAFILE_SERVER_HOSTNAME=xxx.myfritz.net # Specifies your host name if https is enabled.
    depends_on:
      - db
      - memcached
    networks:
      - seafile-net
networks:
  seafile-net:
first, I got an error and I fixed it with a hint from the forum:docker pull seafileltd/seafile-mc:11.0-latest
but now, I get this message:
oot@docker-seafile:/home/seafile# docker compose up -d
[+] Running 2/3
 ✘ seafile Error     manifest for seafileltd/seafile-mc:latest not found: manifest unknown: manifest unknown                                                   1.6s
 ⠴ memcached Pulling        1.6s
 ✘ db Error          context canceled
I found the wrong configuration line:
seafile:
    image: seafileltd/seafile-mc:-latest
changed to
seafile:
    image: seafileltd/seafile-mc:11.0-latest
