I’m in the process of migrating our seafile pro 9 cluster running on centos to seafile pro 11 running on docker.
LDAP login works, but seafile creates a new user after login, and the users have a new library (My Library) created. They don’t see their old libraries.
In my old version 9 server, the system admin opens the “Users” tab. The table shows the tabs “Database”, “LDAP”, “LDAP (imported)”, and “Admin”.
Under Seafile 9 the “Database” tab only shows the admin user. The “LDAP” tab shows all of the found LDAP users of our LDAP server. The “LDAP (imported)” shows all LDAP users, that have logged in to Seafile.
Under Seafile 11 the “Database” tab shows the admin user and all users that have logged in to Seafile. The “LDAP” tab is empty, and the “LDAP (imported)” tab also shows the users that have logged in.
Another observation is, that users are not found, if a user wants to create a share link.
What am I missing? I’ve read the Seafile manual and created the LDAP configuration in seahub_settings.py. And why do the users not find their old libraries? The NFS filesystem is mounted under /opt/seafile-data/seafile/seafile-data. On the old seafile 9 server it is mounted under /home/seafile/seafile-data.
Dirk
