After upgrade docker installation from v12 to v13 LDAP connection is not longer working:
seahub.log is always the same: [2026-01-28 11:36:34] [ERROR] seahub.api2.endpoints.admin.users:955 get Failed to get users from ldap server: {'msgtype': 100, 'msgid': 2, 'result': 1, 'desc': 'Operations error', 'ctrls': [], 'info': '000004DC: LdapErr: DSID-0C090CDE, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, v4563'}.
[2026-01-28 11:36:34] [ERROR] django.request:253 log_response Internal Server Error: /api/v2.1/admin/ldap-users/
The error message LdapErr: DSID-0C090CDE, comment: In order to perform this operation a successful bind must be completed on the connection. clearly indicates that the issue stems from a failed LDAP bind.
Here are the key points to consider:
At present, there are no widespread known issues regarding LDAP bind failures after upgrading from Seafile version 12 to 13.
The root cause is that the Seafile server cannot successfully authenticate with your LDAP server. To investigate this further, you can add debug logs to the relevant code section that handles the LDAP bind operation. This will help you see the exact values being used for the bind DN and password, which can help pinpoint the cause of the failure.
