Hi all,
I’m confused with a AD SSL connection from a Seafile server (7) under CentOS 7.
I have added the following [LDAP] config in ccnet.conf, but got the message “user-mgr.c(242): ldap_initialize failed: Bad parameter to an ldap routine.”.
[LDAP]
HOST = srvad.mydomain.local
USE_SSL = true
BASE = DC=mydomain,DC=local
USER_DN = userseafile@mydomain.local
PASSWORD = password
FILTER = memberOf=cn=GG_RW_SEAFILE,ou=Groupes,dc=mydomain,dc=local
LOGIN_ATTR = mail
Using ldapsarch, I can connect to AD and list users with the same options :
ldapsearch -h srvad.mydomain.local -x -W -D “userseafile@mydomain.local” -b “dc=mydomain,dc=local” “(memberOf=cn=GG_RW_SEAFILE,ou=Groupes,dc=mydomain,dc=local)” “Mail”
What I don’t understand, regarding user-mgr.c on Github, from line 242, is that this message is only possible “ifndef WIN32”. Does this mean “only on non-Windows OS” or am I wrong ? It is the case, I’m on CentOS. But in this case, line 245, USE_SSL is also used only on Windows system ? If we cannot use this option on a linux server, I tried “HOST = ldaps://srvad.mydomain.local”, but got the same error message.
Any idea to solve this (blocking) problem ?
Thanks all
Frank
Hi Jonathan and thank you for quick answering.
Yes, after posting here and reading the source code, that was the conclusion I suspected. I’ve just deleted and recreated all the LDAP config with “ldaps://…”, and the connection pass ! For futur reference, this work, ON LINUX SERVER:
[LDAP]
BASE = OU=Users,DC=mydomain,DC=local
PASSWORD = password
FILTER = memberOf=CN=GG_RW_SEAFILE,OU=Groups,DC=mydomain,DC=local
LOGIN_ATTR = Mail
If successful, a window is displayed listing information related to the active directory SSL connection. If the connection is unsuccessful, restart your system
