According to the documentation ( Account management - Seafile Admin Manual ), a user’s password can be reset under the System Admin section.
Administrator can reset password for a user in “System Admin” page.
In another topic ( No Login after Upgrade - #5 by daniel.pan ) it was mentioned:
Then you can reset password for that user to a simple one and try again.
However using the “Password reset” action only sends a password reset e-mail to the user. Is there no way (anymore) to manually set a temporary password?
Using Seafile 13.0.12 CE, Docker Installation.
Thanks!
