after some difficulties with portainer (basically a new install), I redeployed my seafile stack but the database server seems to be in a constant error loop.
Mariadb Container Log
2026-02-24 11:24:46 0 [Note] mariadbd: O_TMPFILE is not supported on /tmp (disabling future attempts)
2026-02-24 11:24:46 0 [Warning] mariadbd: io_uring_queue_init() failed with EPERM: sysctl kernel.io_uring_disabled has the value 2, or 1 and the user of the process is not a member of sysctl kernel.io_uring_group. (see man 2 io_uring_setup).
create_uring failed: falling back to libaio
2026-02-24 11:24:46 0 [Note] InnoDB: Using Linux native AIO
2026-02-24 11:24:46 0 [Note] InnoDB: innodb_buffer_pool_size_max=128m, innodb_buffer_pool_size=128m
2026-02-24 11:24:46 0 [Note] InnoDB: Completed initialization of buffer pool
2026-02-24 11:24:46 0 [Note] InnoDB: File system buffers for log disabled (block size=512 bytes)
2026-02-24 11:24:46 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=17055
2026-02-24 11:24:46 0 [Note] InnoDB: End of log at LSN=36381
2026-02-24 11:24:46 0 [Note] InnoDB: To recover: 2 pages
2026-02-24 11:24:46 0 [Note] InnoDB: 128 rollback segments are active.
2026-02-24 11:24:46 0 [Note] InnoDB: Removed temporary tablespace data file: “./ibtmp1”
2026-02-24 11:24:46 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12.000MiB. Physically writing the file full; Please wait …
2026-02-24 11:24:46 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12.000MiB.
2026-02-24 11:24:46 0 [Note] InnoDB: log sequence number 36381; transaction id 4
2026-02-24 11:24:46 0 [Note] Plugin ‘FEEDBACK’ is disabled.
2026-02-24 11:24:46 0 [ERROR] Can’t open and lock privilege tables: Table ‘mysql.servers’ doesn’t exist
2026-02-24 11:24:46 0 [Warning] Can’t open and lock time zone table: Table ‘mysql.time_zone_leap_second’ doesn’t exist trying to live without them
2026-02-24 11:24:46 1 [Warning] Failed to load slave replication state from table mysql.gtid_slave_pos: 1146: Table ‘mysql.gtid_slave_pos’ doesn’t exist
2026-02-24 11:24:46 0 [Note] mariadbd: ready for connections.
Version: ‘10.11.15-MariaDB-ubu2204’ socket: ‘/run/mysqld/mysqld.sock’ port: 0 mariadb-org binary distribution
2026-02-24 11:24:47+00:00 [Note] [Entrypoint]: Temporary server started.
2026-02-24 11:24:47+00:00 [Note] [Entrypoint]: Backing up system database to system_mysql_backup_10.11.13-MariaDB.sql.zst
Error: Couldn’t read status information for table general_log ()
mariadb-dump: Couldn’t execute ‘show create table general_log’: Table ‘mysql.general_log’ doesn’t exist (1146)
2026-02-24 11:24:47+00:00 [ERROR] [Entrypoint]: Unable backup system database for upgrade from 10.11.13-MariaDB.
2026-02-24 11:24:54+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.11.15+maria~ubu2204 started.
2026-02-24 11:24:54+00:00 [Warn] [Entrypoint]: /sys/fs/cgroup///memory.pressure not writable, functionality unavailable to MariaDB
2026-02-24 11:24:54+00:00 [Note] [Entrypoint]: Switching to dedicated user ‘mysql’
2026-02-24 11:24:54+00:00 [Note] [Entrypoint]: MariaDB healthcheck configuration file missing, assuming desirable
2026-02-24 11:24:54+00:00 [Note] [Entrypoint]: Starting temporary server
2026-02-24 11:24:54+00:00 [Note] [Entrypoint]: Waiting for server startup
2026-02-24 11:24:54 0 [Note] Starting MariaDB 10.11.15-MariaDB-ubu2204 source revision cb0d6dd835023a7162ace471cd047161f205dd58 server_uid iw69kuaTtimU6cJbfpbfypL1qs0= as process 58
2026-02-24 11:24:55 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2026-02-24 11:24:55 0 [Note] InnoDB: Number of transaction pools: 1
2026-02-24 11:24:55 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2026-02-24 11:24:55 0 [Note] mariadbd: O_TMPFILE is not supported on /tmp (disabling future attempts)
2026-02-24 11:24:55 0 [Warning] mariadbd: io_uring_queue_init() failed with EPERM: sysctl kernel.io_uring_disabled has the value 2, or 1 and the user of the process is not a member of sysctl kernel.io_uring_group. (see man 2 io_uring_setup).
2026-02-24 11:24:55 0 [Note] InnoDB: Using Linux native AIO
2026-02-24 11:24:55 0 [Note] InnoDB: innodb_buffer_pool_size_max=128m, innodb_buffer_pool_size=128m
2026-02-24 11:24:55 0 [Note] InnoDB: Completed initialization of buffer pool
2026-02-24 11:24:55 0 [Note] InnoDB: File system buffers for log disabled (block size=512 bytes)
2026-02-24 11:24:55 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=17055
2026-02-24 11:24:55 0 [Note] InnoDB: End of log at LSN=36381
2026-02-24 11:24:55 0 [Note] InnoDB: To recover: 2 pages
2026-02-24 11:24:55 0 [Note] InnoDB: 128 rollback segments are active.
2026-02-24 11:24:55 0 [Note] InnoDB: Removed temporary tablespace data file: “./ibtmp1”
2026-02-24 11:24:55 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12.000MiB. Physically writing the file full; Please wait …
2026-02-24 11:24:55 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12.000MiB.
2026-02-24 11:24:55 0 [Note] InnoDB: log sequence number 36381; transaction id 4
2026-02-24 11:24:55 0 [Note] Plugin ‘FEEDBACK’ is disabled.
2026-02-24 11:24:55 0 [ERROR] Can’t open and lock privilege tables: Table ‘mysql.servers’ doesn’t exist
2026-02-24 11:24:55 0 [Warning] Can’t open and lock time zone table: Table ‘mysql.time_zone_leap_second’ doesn’t exist trying to live without them
2026-02-24 11:24:55 1 [Warning] Failed to load slave replication state from table mysql.gtid_slave_pos: 1146: Table ‘mysql.gtid_slave_pos’ doesn’t exist
2026-02-24 11:24:55 0 [Note] mariadbd: ready for connections.
2026-02-24 11:24:55+00:00 [Note] [Entrypoint]: Temporary server started.
2026-02-24 11:24:55+00:00 [Note] [Entrypoint]: Backing up system database to system_mysql_backup_10.11.13-MariaDB.sql.zst
2026-02-24 11:24:55+00:00 [ERROR] [Entrypoint]: Unable backup system database for upgrade from 10.11.13-MariaDB.
2026-02-24 11:25:09+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.11.15+maria~ubu2204 started.
2026-02-24 11:25:09+00:00 [Warn] [Entrypoint]: /sys/fs/cgroup///memory.pressure not writable, functionality unavailable to MariaDB
2026-02-24 11:25:09+00:00 [Note] [Entrypoint]: Switching to dedicated user ‘mysql’
2026-02-24 11:25:09+00:00 [Note] [Entrypoint]: MariaDB healthcheck configuration file missing, assuming desirable
2026-02-24 11:25:09+00:00 [Note] [Entrypoint]: Starting temporary server
2026-02-24 11:25:09+00:00 [Note] [Entrypoint]: Waiting for server startup
2026-02-24 11:25:09 0 [Note] Starting MariaDB 10.11.15-MariaDB-ubu2204 source revision cb0d6dd835023a7162ace471cd047161f205dd58 server_uid aE1oGXhkn5VxJGe5d+FmCXe3YDU= as process 58
2026-02-24 11:25:09 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2026-02-24 11:25:10 0 [Note] InnoDB: Number of transaction pools: 1
2026-02-24 11:25:10 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2026-02-24 11:25:10 0 [Note] mariadbd: O_TMPFILE is not supported on /tmp (disabling future attempts)
2026-02-24 11:25:10 0 [Warning] mariadbd: io_uring_queue_init() failed with EPERM: sysctl kernel.io_uring_disabled has the value 2, or 1 and the user of the process is not a member of sysctl kernel.io_uring_group. (see man 2 io_uring_setup).
2026-02-24 11:25:10 0 [Note] InnoDB: Using Linux native AIO
2026-02-24 11:25:10 0 [Note] InnoDB: innodb_buffer_pool_size_max=128m, innodb_buffer_pool_size=128m
2026-02-24 11:25:10 0 [Note] InnoDB: Completed initialization of buffer pool
2026-02-24 11:25:10 0 [Note] InnoDB: File system buffers for log disabled (block size=512 bytes)
2026-02-24 11:25:10 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=17055
2026-02-24 11:25:10 0 [Note] InnoDB: End of log at LSN=36381
2026-02-24 11:25:10 0 [Note] InnoDB: To recover: 2 pages
2026-02-24 11:25:10 0 [Note] InnoDB: 128 rollback segments are active.
2026-02-24 11:25:10 0 [Note] InnoDB: Removed temporary tablespace data file: “./ibtmp1”
2026-02-24 11:25:10 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12.000MiB. Physically writing the file full; Please wait …
2026-02-24 11:25:10 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12.000MiB.
2026-02-24 11:25:10 0 [Note] InnoDB: log sequence number 36381; transaction id 4
2026-02-24 11:25:10 0 [Note] Plugin ‘FEEDBACK’ is disabled.
2026-02-24 11:25:10 0 [ERROR] Can’t open and lock privilege tables: Table ‘mysql.servers’ doesn’t exist
2026-02-24 11:25:10 0 [Warning] Can’t open and lock time zone table: Table ‘mysql.time_zone_leap_second’ doesn’t exist trying to live without them
2026-02-24 11:25:10 1 [Warning] Failed to load slave replication state from table mysql.gtid_slave_pos: 1146: Table ‘mysql.gtid_slave_pos’ doesn’t exist
After stopping the stack I checked the db folder and the previous contents are now deleted. I have this folder backed up but did not export any .sql files from the container as per backing-up-database guide.
How can I redeploy the stack with the database intact?
If this is not possible, do i just start the stack, pause the database and use the FSCK tool from inside the seafile container?
Thanks in advance!
