Before when they still worked (ubuntu 14.04) I had also problems as they threw a few errors on startup of seafile and only were quite after a few seconds.
Why is the setup I’m using now not the preferred one ?
Edit: Reinstalled django_pylibmc and pylibmc and now it starts with some errors in seahub.log
2018-01-16 15:41:35,952 [ERROR] django.pylibmc:132 get MemcachedError: error 26 from memcached_get(:1:throttle_user_605): Transport endpoint is not connected
File “/usr/local/lib/python2.7/dist-packages/django_pylibmc/memcached.py”, line 130, in get
return super(PyLibMCCache, self).get(key, default, version)
File “/srv/seafile/informatik/seafile-server-6.2.3/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/cache/backends/memcached.py”, line 84, in get
val = self._cache.get(key)
To read how to use it over socket then you need to locate that section in the installation guide - in this guide you can also read what package you need to install to get it to work. https://nohatech.se/how-to-setup-seafile-ubuntu/
Have you installed the following package?
python-memcache memcached libmemcached-dev zlib1g-dev
Edit:
6.2.3 have a bug in memeached, pasted this text from my guide:
If your running 6.2.3 you need to do a fix before using memcached
Before your doing the changes you need to stop Seafile.
cd /opt/nohatech/seafile-server-latest/
./seafile.sh stop
./seahub.sh stop
Then you need to open the file that we are going to change.
