I see tons of messages like:
[12/21/2017 05:02:35 PM] …/common/obj-cache.c(106): Failed to set BLOCKEXISTENCE2-e612a24e-0
2f8-44fa-8700-ea2b4e05e7bf-8e47e5016965f1d85b0fb87a5ad3765b7b7bd3e6 to memcached: SERVER IS M
ARKED DEAD.
2f8-44fa-8700-ea2b4e05e7bf-d35cfdf918728a179159893ea9cbc4b540a5633c to memcached: SERVER IS M
ARKED DEAD.
[12/21/2017 05:02:38 PM] …/common/obj-cache.c(106): Failed to set 996762a1-36bc-42d8-99fd-9b
ff3d1ca46b-d524f40b26c055507df74b7bbdf87193d4ed27fd to memcached: SERVER IS MARKED DEAD.
[12/21/2017 05:02:38 PM] …/common/obj-cache.c(106): Failed to set 442a5890-86b8-4a96-8589-d0
6860390364-ef4e3620cda97a241d1aa71372d1969a17136071 to memcached: SERVER IS MARKED DEAD.
however, all my memcached servers are up and running. so I do not really understand the meaning of these messages nor do I have any clue, what I should do to get rid of them.
Any hint appreciated.
Hp
I am using:
seafile pro 6.1.8
memcached 1.4.21
on a debian jessie
you mean turning off/on memcached? yes. furthermore I can talk to all my memcache daemons. they are up and running.
(I have a seafile cluster).
Clear the cache sounds like a very good idea. Which cache do you mean? Has memcache a cache to be cleared? (sounds a bit funny, cache of the cache). Any hints welcome, I am not at all an expert with memcache.
there is no firewall issue, as mentioned I can talk (from all cluster machines) to all memcached instances.
I have this errors since a long time. Rebooting the whole cluster makes absolutely no difference.
could this come from the fact that this is a seafile cluster? If I reboot the cluster, I do this one machine after the other. So, except the machine which is rebooted last, all the other have seen outages of the other machines.
I see this errors always on the machine, that is the primary server (handling the requests from the clients and the web interface).
if you think this is a configuration issue, let me know which parts of the configuration you like to see.
My seafile installation works perfectly, so I am not sure if these memcached error messages are really errors, or just “hickups” of memcached. In other words, these error nessage have no negative impact on the user experience. Sometimes we see “internal server error” when users try to access encrypted libraries, but I am not sure, if this is related to memcached.
would clearing the memcache cache help? or is this a dangerous operation?
That’s related to memcached and your system should be slower than normal. For me it looks like one or more memcached servers just don’t work.
I already saw such errors if you use more than one memcached server and just one is dead. So it would be better if you can test it with one. And that’s one of the reasons why redis will be supported in future seafile versions.
this is nice to hear.
On the primary server, which sees a lot of these memcache errors, I can telnet to all three memcached server without any problems. I also took the opportunity to clear all memcache caches (using flush_all in the telnet session). Please believe me, my memcached servers are running.
We are talking about a production environment here. I am willing to do experiments to some extent, but I would first like to understand what we would gain by doing them. why should it work better with one server? and how would this help us in solving my current error messages?
please understand that I cannot undertake such experiments lightly.
and be assured, I am very grateful for your help.
As i already told you, there may be problems if you use more than one memcached servers. So i would like to see what happens if you just use one.
And if just one works, this is better than the current state:
You wrote that you’re just using hot standby setup, so if one webserver is down you still have to do work manually to switch over to the other system, that’s not HA, so why do you want to have memcached HA? - Certainly not if it does not work properly.
