Hi Jonathan,
it’s just:
[cluster]
enabled = true
memcached_options = --SERVER=10.94.7.156 --POOL-MIN=10 --POOL-MAX=100
Regards, Moritz
Hi Jonathan,
it’s just:
[cluster]
enabled = true
Regards, Moritz
We tried similar setup (CACHES = {…} in seahub_settings.py), but with haproxy instead of heartbeat. Thus sefaile nodes has always one IP to access memcached. The configuration seems to be stable, but seahub.log of other nodes is full of following exceptions:
2018-02-14 16:38:20,674 [ERROR] django.pylibmc:125 add MemcachedError: memcached_behavior_set returned 38
for behavior 'remove_failed' = 0
File "/usr/local/lib/python2.7/dist-packages/django_pylibmc/memcached.py", line 117, in add
return self._cache.add(key, value,
File "/usr/local/lib/python2.7/dist-packages/django_pylibmc/memcached.py", line 93, in _cache
client.behaviors = self._options
File "/usr/local/lib/python2.7/dist-packages/pylibmc/client.py", line 197, in set_behaviors
return super(Client, self).set_behaviors(_behaviors_numeric(behaviors))
Error: memcached_behavior_set returned 38 for behavior 'remove_failed' = 0
Do you have same errors? Can we just ignore them?
I suggest for single memcache server, all the options be removed.
I suspect that ketama hashing should be used together with remove_failed=1
I agree with Daniel that the above configuration should be removed from seahub_setting.py.
@schlarbm you observed “marked dead” because “remove_failed” and “ketama” option are hard coded in the C code right now. We will change this and also change the documentation too. (BTW, after some testing, I find that adding --RETRY-TIMEOUT=1 to seafile.conf would also avoid the “marked dead” situation too. But I prefer not to recommend to adding one more option to the config file.)
At last, the memcached config in seafile.conf should be:
[cluster]
enabled = true
memcached_options = --SERVER=ip --POOL-MIN=10 --POOL-MAX=100
in seahub_settings.py should be
CACHES = {
'default': {
'LOCATION': ['ip:11211'],
Hi Jonathan!
Ah, okay!
The two snippets you posted are exactly what we currently have - and apart from that one instance there are no problems at the moment.
We wish you a happy new year holiday!
Moritz
@vmakarenko Have you solved your memcached issue with the new configuration?
We changed to memcached/keepalived solution. The setup works stable if keepalived points to one memcached instance. But we have similar issues if keepalived switches to backup memcached instance or goes back to master. Seafile cannot recover from this status: seafile server complains about Bad Access Token on background task server or nodes send empty urls to it. The only complete restart of all infrastucture (app nodes + background task server) fixes the problem. Shell I send our confs?
Hi @vmakarenko
Please provide the following config options:
Please also provide the error messages in seafile.log when you switch over the memcached server.
By the way, have you confirmed that the VIP has been migrated to the stand-by memcached server when the main server is shutdown?
seafile.conf:
[cluster]
enabled = true
memcached_options = --SERVER=V_IP:11211 --POOL-MIN=10 --POOL-MAX=100
health_check_port = 11001
seahub_settings.py
CACHES = {
'default': {
'LOCATION': 'V_IP:11211',
keepalived.conf at any of 2 MEMCACHED instances, the only difference: priority 200, 101, 100
lobal_defs {
notification_email {
SYSADMIN_EMAIL
notification_email_from SYSADMIN_EMAIL
smtp_server localhost
smtp_connect_timeout 30
vrrp_garp_interval 5
vrrp_garp_master_delay 5
vrrp_garp_master_repeat 5
vrrp_script check_memcached {
script "/usr/lib/nagios/plugins/check_memcached.pl -H localhost"
interval 2 # check every 2 seconds
fall 2 # require 2 failures for KO
rise 2 # require 2 successes for OK
vrrp_instance memcached {
state MASTER
interface eth0
virtual_router_id 56
priority 200
advert_int 1
smtp_alert
authentication {
auth_type PASS
auth_pass PASSWORD
unicast_peer {
MEMCACHED_INSTANCE_1_IP
MEMCACHED_INSTANCE_2_IP
MEMCACHED_INSTANCE_3_IP
virtual_ipaddress {
V_IP
track_script {
check_memcached
notify /usr/local/bin/keepalived_status.sh
We checked VIP switching: completely fine with the keepalived settings.
seafile-background-tasks.log at background tatsks server after switching of MEMCACHED instance with keepalived:
[2018-03-05 16:48:39,688] [WARNING] failed to fetch document of task (http://127.0.0.1:8082/files/38487e0f-b91d-4762-a921-266cbbea6ff7/A%20Flexible%20Graph-Based%20Data%20Model%20Supporting%20incremental%20Schema%20Design%20and%20evolution.pdf): HTTP Error 400: Bad Request
w3m http://127.0.0.1:8082/files/38487e0f-b91d-4762-a921-266cbbea6ff7/A%20Flexible%20Graph-Based%20Data%20Model%20Supporting%20incremental%20Schema%20Design%20and%20evolution.pdf "Bad access token"
Hi @vmakarenko
Please have a try this test package: https://download.seafile.com/f/94eaf35cae4842219cc9/?dl=1
The config in seahub_settings.py and seafile.conf need not be changed.
Thank you Jonathan, we will test the package. BTW, I am just cuirious, what has been fixed/changed?
We have removed the hard coded ‘ketama’ and ‘remove_failed’ options in seaf-server. I think your error when switching memcached instances was caused by these options. It doesn’t mean there won’t be any error, but it should recover by itself after the switch is done.
Hi all,
The fix has been included in 6.2.11. New configuration for memcached and Seafile can be found in https://manual.seafile.com/deploy_pro/deploy_in_a_cluster.html. Just search for “memcached configuration”.
Redis will be supported soon?
