Is there a way to mount seafile libraries from the Windows server like the fuse client on Linux? I know that the SeaDrive client can do that but I don’t want to sync between two different locations on the server. I’m wanting to be able to view the files from the server so that I can continue to have traditional file system access without a second synched copy of the files.
You can use WebDAV.
But unfortunately that does not work flawless with standard OS software like Finder and Explorer.
But I guess this would be the starting point and with the right tools it could be what you want.
