I’m trying to setup a seafile server with the offical docker-compose.yml.
After starting the containers I found an error-message in seafile-mysql container:
[Warning] Access denied for user 'seafile'@'172.18.0.4' (using password: YES
I didn’t change the standard-password “db_dev”
It is also not possible to login in the mysql-container.
This is my docker-compose.yml:
db:
image: mariadb:10.11
container_name: seafile-mysql
- MYSQL_ROOT_PASSWORD=db_dev # Requested, set the root's password of MySQL service.
- MYSQL_LOG_CONSOLE=true
- MARIADB_AUTO_UPGRADE=1
- /opt/seafile-mysql/db:/var/lib/mysql # Requested, specifies the path to MySQL data persistent store.
networks:
- seafile-net
memcached:
image: memcached:1.6.18
entrypoint: memcached -m 256
networks:
- seafile-net
# elasticsearch:
# image: elasticsearch:8.6.2
# container_name: seafile-elasticsearch
# environment:
# - discovery.type=single-node
# - bootstrap.memory_lock=true
# - "ES_JAVA_OPTS=-Xms1g -Xmx1g"
# - "xpack.security.enabled=false"
# ulimits:
# memlock:
# soft: -1
# hard: -1
# mem_limit: 2g
# volumes:
# - /opt/seafile-elasticsearch/data:/usr/share/elasticsearch/data # Requested, specifies the path to Elasticsearch data persistent store.
# networks:
# - seafile-net
seafile:
image: docker.seadrive.org/seafileltd/seafile-pro-mc:latest
- "8075:80"
# - "443:443" # If https is enabled, cancel the comment.
- /media/usbdrive/Seafile/seafile-data:/shared # Requested, specifies the path to Seafile data persistent store.
- DB_HOST=db
- DB_ROOT_PASSWD=db_dev # Requested, the value should be root's password of MySQL service.
- TIME_ZONE=Europe/Berlin # Optional, default is UTC. Should be uncomment and set to your local time zone.
- SEAFILE_ADMIN_EMAIL=xy.z@test.de # Specifies Seafile admin user, default is 'me@example.com'
- SEAFILE_ADMIN_PASSWORD=topsecret # Specifies Seafile admin password, default is 'asecret'
- SEAFILE_SERVER_LETSENCRYPT=false # Whether to use https or not
- SEAFILE_SERVER_HOSTNAME=192.168.178.75 # Specifies your host name if https is enabled
depends_on:
- db
- memcached
- elasticsearch
networks:
- seafile-net
networks:
seafile-net:
How can I change the root-password?
