Do a google search for “seafile docker”
Click the first link (github)
Scroll down and click the link on this line: " If you plan to deploy seafile 7.0, you should refer to the Deploy Documentation"
Find the section " Download and modify docker-compose.yml"
In the example file there are two lines you have to modify, both “Volumes” options, pointing them to the appropriate location on the host.
