Hi everyone.
I updatet my seafile server from 6.1.2 to 6.2.2 and I want not to use my old nginx fast-cgi config. I wanted to use it without fastcgi now. The server works fine, but nginx doesn’t redirect my connection to the seafile server. I updatet nginx to version 1.12.2 too. Here is my sites-enabled config. Maybe I have a stupid error in it and someone can help me?
(I changed my server_name to MY.SERVER.COM in this example ^^)
listen 80;
server_name MY.SERVER.COM;
# Enables or disables emitting nginx version on error pages and in the "Server" response header field.
server_tokens off;
listen 8001;
ssl on;
ssl_certificate /etc/nginx/ssl/seahub.crt; # path to your cacert.pem
ssl_certificate_key /etc/nginx/ssl/seahub.key; # path to your privkey.pem
server_tokens off;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
proxy_request_buffering off;
root /home/seafile/haiwen/seafile-server-latest/seahub;
When I try to visit the website over port 8001 wia https, the connection will be refused:
ERR_CONNECTION_REFUSED
Anyone an idea?
Greetings
MasterFox
