Currently have two setups both using reverse proxies. One is with apache24 and I’m a bit more familiar with. The other nginx which I am converting my all my services to. There are two hosts, one at 127.0.10.3 which is the seafile server. The web server with nginx and apache24 is at 127.0.10.1. This is running on FreeBSD 11-STABLE.
The apache configuration works perfectly. Here is the config:
vhost.conf:
<VirtualHost *:443>
ServerName seafile.domain.com
ServerAlias seafile.domain.com
TransferLog “/var/log/httpd-access.log”
Protocols h2 http/1.1
Header always set Strict-Transport-Security "max-age=63072000; includeSubDomains"
RewriteEngine On
ProxyPass /seafhttp http://127.0.10.3:8082
ProxyPassReverse /seafhttp http://127.0.10.3:8082
SetEnvIf Request_URI . proxy-fcgi-pathinfo=unescape
# The .well-known is for letsencrypt
ProxyPassMatch ^(?!/.well-known) fcgi://127.0.10.3:8000
SSLEngine on
SSLCertificateFile "/usr/local/etc/letsencrypt/live/seafile.domain.com/cert.pem"
SSLCertificateKeyFile "/usr/local/etc/letsencrypt/live/seafile.domain.com/privkey.pem"
SSLCACertificateFile "/usr/local/etc/letsencrypt/live/seafile.domain.com/chain.pem"
</VirtualHost>
So i’v been using this for quite awhile and it works perfectly. With nginx, I ran into one issue. The /seafhttp proxy is returning this:
HTTP/1.0 400 Bad Request
Content-Type: text/plain
I tried different configurations and just couldn’t figure out why this error is occurring. I decided to get rid of my complex config and provide a simple one and it still fails. Here is the simple config.
nginx.conf:
#user nobody;
worker_processes 1;
# This default error log path is compiled-in to make sure configuration parsing
# errors are logged somewhere, especially during unattended boot when stderr
# isn't normally logged anywhere. This path will be touched on every nginx
# start regardless of error log location configured here. See
# https://trac.nginx.org/nginx/ticket/147 for more info.
#error_log /var/log/nginx/error.log;
#pid logs/nginx.pid;
events {
worker_connections 1024;
http {
include mime.types;
sendfile on;
keepalive_timeout 65;
listen 80;
server_name seafile.domain.com;
server_tokens off;
listen 443;
ssl on;
ssl_certificate /usr/local/etc/letsencrypt/live/seafile.domain.com/cert.pem; # path to your cacert.pem
ssl_certificate_key /usr/local/etc/letsencrypt/live/seafile.domain.com/privkey.pem; # path to your privkey.pem
ssl_trusted_certificate /usr/local/etc/letsencrypt/live/seafile.domain.com/chain.pem;
ssl_session_timeout 5m;
# ssl_dhparam /etc/nginx/dhparam.pem;
# secure settings (A+ at SSL Labs ssltest at time of writing)
# see https://wiki.mozilla.org/Security/Server_Side_TLS#Nginx
ssl_ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:EC
DHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:DHE-RSA-CAMELLIA256-SHA:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES128-SHA256:DHE-RSA-AES128
-SHA:DHE-RSA-SEED-SHA:DHE-RSA-CAMELLIA128-SHA:HIGH:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS';
ssl_prefer_server_ciphers on;
server_tokens off;
fastcgi_pass 127.0.10.3:8000;
fastcgi_param HTTPS on;
fastcgi_read_timeout 36000;
proxy_pass http://127.0.10.3:8082;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
If anyone has an idea why the nginx config is failing I would appreciate it!
Best regards,
Ultima
