Nginx/reverse proxy + nginx/seafile
I am able to access my Seafile server locally and externally. However, I am able to download/upload files only based on what I put in the WebUI’s SERVICE_URL, FILE_SERVER_ROOT.
I am able to download/upload files locally if:
SERVICE_URL = https://192.168.0.15
FILE_SERVER_ROOT = https://192.168.0.15/seafhttp
and externally if I have:
SERVICE_URL = https://domainname.com
FILE_SERVER_ROOT = https://domainname.com/seafhttp
But not both! What am i doing wrong?
My setup is:
  • VM1: wan nginx (reverse proxy), Letsencrypt SSL cert
  • VM2: lan nginx + seafile, self signed SSL cert
VM1 wan-nginx config:
server  {
  listen  80;
  server_name  mydomainname.com;
  return 301 https://$server_name/$1;
server  {
  listen 443;
  ssl  on;
  ssl_certificate  /etc/letsencrypt/live/mydomainname.com/fullchain.pem;
  ssl_certificate_key /etc/letsencrypt/live/mydomainname.com/privkey.pem;
  ssl_dhparam  /etc/ssl/certs/dhparam.pem;
  ssl_session_timeout  5m;
  ssl_prefer_server_ciphers  on;
  ssl_protocols  TLSv1 TLSv1.1 TLSv1.2;
  ssl_ciphers  AES256+EECDH:AES256+EDH:!aNULL;
  server_tokens off;
  access_log /var/log/nginx/mydomainname.com_access.log;
  error_log /var/log/nginx/mydomainname.com_error.log;
  location  / {
     proxy_pass  https://192.168.0.15;
     proxy_set_header X-Forwarded-for $proxy_add_x_forwarded_for;
     proxy_set_header Host $host;
     proxy_hide_header X-Powered-By;
      proxy_pass http://192.168.0.15:8082;
      proxy_read_timeout  36000s;
VM2 lan nginx config:
            listen       80;
            listen 443;
            ssl on;
            ssl_certificate         /etc/ssl/seafile_cacert.pem;
            ssl_certificate_key     /etc/ssl/seafile_privkey.pem;
            fastcgi_param   SERVER_PROTOCOL       $server_protocol;
            add_header X-UA-Compatible "IE=Edge,chrome=1";
You ever get this working? I am interested in the exact same configuration for obvious reasons.
Use the external address in the server config and all clients. Then configure your local / internal DNS settings (firewall / router) to resolve the external hostname to the internal IP address and everything should work fine.
So if you are in your local network, the hostname will be resolved to the internal IP, if you are external (and do not use your internal DNS Server) it will provide the external IP.
I did what marcusm suggested, as well as edited the hosts (exists in *nix and windows) file on the LAN machines that I wanted to resolve the LAN and not WAN address for internal network only synchs.
On my LAN installation we don’t have any DNS services running (By design, and won’t be changed) and wanted to make sure both LAN/WAN went well and via the expected areas.
Yes this works as long as your PC/Laptop does not switch between WAN/LAN, because it will resolve the internal IP even if you’re in the WAN, which would not work.
So in this scenario a local DNS Server which would be assigned via DHCP is the best solution but if you don’t switch between networks, it works with the hosts file.
marcusm,
Agreed on all of your points.
The setup works for me because the clients I edited the hosts file on do not move networks, and in one of my installations DNS/DHCP is not an option.
