I’ve upgraded our Seafile 9.0.16 to 10.0.14 with following the documentation. Now everything works but web ui gives Internal Server Error.
I inpected the log files but couldn’t find any error.
What can i do now?
What can i do now?
I found a problem with python3 pip and do the following to fix this issue:
sudo apt remove python3-pip
wget https://bootstrap.pypa.io/get-pip.py
sudo python3 get-pip.py
After reboot
pip install pyopenssl --upgrade
Now web ui is working fine.
Thanks for posting the solution. It’s important to document the fixes.
