Having the similar problem
it works with S3 self-hosted minio on http
but on https I am getting
<type ‘exceptions.ValueError’> with a very colourful and very long list of python analysis.
A problem occurred in a Python script. Here is the sequence of function calls leading up to the error, in the order they occurred.
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/flup/server/fcgi_base.py in run(self=<flup.server.fcgi_base.Request object>)
556 """Runs the handler, flushes the streams, and ends the request."""
557 try:
=> 558 protocolStatus, appStatus = self.server.handler(self)
559 except:
560 traceback.print_exc(file=self.stderr)
protocolStatus undefined, appStatus undefined, self = <flup.server.fcgi_base.Request object>, self.server = <flup.server.fcgi.WSGIServer object>, self.server.handler = <bound method WSGIServer.handler of <flup.server.fcgi.WSGIServer object>>
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/flup/server/fcgi_base.py in handler(self=<flup.server.fcgi.WSGIServer object>, req=<flup.server.fcgi_base.Request object>)
1118 result = self.application(environ, start_response)
1119 try:
=> 1120 for data in result:
1121 if data:
1122 write(data)
data undefined, result = <generator object __call__>
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/wsgidav/wsgidav_app.py in __call__(self=<wsgidav.wsgidav_app.WsgiDAVApp object>, environ={'CONTENT_LENGTH': '', 'CONTENT_TYPE': '', 'HTTPS': 'on', 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'HTTP_ACCEPT_ENCODING': 'gzip, deflate, br', 'HTTP_ACCEPT_LANGUAGE': 'en-US,en;q=0.5', 'HTTP_AUTHORIZATION': 'Basic YWRtaW5Aa2lzaWVsLm5ldC5wbDpwcmVkaWN0IHVuYWZyYWlkIHN1cnZpdm9yIGNoYWluIHdyZWNrYWdlIHB1cmlmaWVy', 'HTTP_CACHE_CONTROL': 'max-age=0', 'HTTP_HOST': 'seafile.kisiel.net.pl', 'HTTP_SCHEME': 'https', ...}, start_response=<function start_response>)
395 # Call next middleware
396 app_iter = self._application(environ, _start_response_wrapper)
=> 397 for v in app_iter:
398 yield v
399 if hasattr(app_iter, "close"):
v undefined, app_iter = <generator object __call__>
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/wsgidav/debug_filter.py in __call__(self=<wsgidav.debug_filter.WsgiDavDebugFilter object>, environ={'CONTENT_LENGTH': '', 'CONTENT_TYPE': '', 'HTTPS': 'on', 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'HTTP_ACCEPT_ENCODING': 'gzip, deflate, br', 'HTTP_ACCEPT_LANGUAGE': 'en-US,en;q=0.5', 'HTTP_AUTHORIZATION': 'Basic YWRtaW5Aa2lzaWVsLm5ldC5wbDpwcmVkaWN0IHVuYWZyYWlkIHN1cnZpdm9yIGNoYWluIHdyZWNrYWdlIHB1cmlmaWVy', 'HTTP_CACHE_CONTROL': 'max-age=0', 'HTTP_HOST': 'seafile.kisiel.net.pl', 'HTTP_SCHEME': 'https', ...}, start_response=<function _start_response_wrapper>)
152 app_iter = self._application(environ, sub_app_start_response)
153
=> 154 for v in app_iter:
155 # Start response (the first time)
156 if first_yield:
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/wsgidav/error_printer.py in __call__(self=<wsgidav.error_printer.ErrorPrinter object>, environ={'CONTENT_LENGTH': '', 'CONTENT_TYPE': '', 'HTTPS': 'on', 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'HTTP_ACCEPT_ENCODING': 'gzip, deflate, br', 'HTTP_ACCEPT_LANGUAGE': 'en-US,en;q=0.5', 'HTTP_AUTHORIZATION': 'Basic YWRtaW5Aa2lzaWVsLm5ldC5wbDpwcmVkaWN0IHVuYWZyYWlkIHN1cnZpdm9yIGNoYWluIHdyZWNrYWdlIHB1cmlmaWVy', 'HTTP_CACHE_CONTROL': 'max-age=0', 'HTTP_HOST': 'seafile.kisiel.net.pl', 'HTTP_SCHEME': 'https', ...}, start_response=<wsgidav.util.SubAppStartResponse object>)
40 # Otherwise the we could not catch exceptions here.
41 response_started = False
=> 42 app_iter = self._application(environ, sub_app_start_response)
43 for v in app_iter:
44 # Start response (the first time)
app_iter undefined, self = <wsgidav.error_printer.ErrorPrinter object>, self._application = <wsgidav.http_authenticator.HTTPAuthenticator object>, environ = {'CONTENT_LENGTH': '', 'CONTENT_TYPE': '', 'HTTPS': 'on', 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'HTTP_ACCEPT_ENCODING': 'gzip, deflate, br', 'HTTP_ACCEPT_LANGUAGE': 'en-US,en;q=0.5', 'HTTP_AUTHORIZATION': 'Basic YWRtaW5Aa2lzaWVsLm5ldC5wbDpwcmVkaWN0IHVuYWZyYWlkIHN1cnZpdm9yIGNoYWluIHdyZWNrYWdlIHB1cmlmaWVy', 'HTTP_CACHE_CONTROL': 'max-age=0', 'HTTP_HOST': 'seafile.kisiel.net.pl', 'HTTP_SCHEME': 'https', ...}, sub_app_start_response = <wsgidav.util.SubAppStartResponse object>
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/wsgidav/http_authenticator.py in __call__(self=<wsgidav.http_authenticator.HTTPAuthenticator object>, environ={'CONTENT_LENGTH': '', 'CONTENT_TYPE': '', 'HTTPS': 'on', 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'HTTP_ACCEPT_ENCODING': 'gzip, deflate, br', 'HTTP_ACCEPT_LANGUAGE': 'en-US,en;q=0.5', 'HTTP_AUTHORIZATION': 'Basic YWRtaW5Aa2lzaWVsLm5ldC5wbDpwcmVkaWN0IHVuYWZyYWlkIHN1cnZpdm9yIGNoYWluIHdyZWNrYWdlIHB1cmlmaWVy', 'HTTP_CACHE_CONTROL': 'max-age=0', 'HTTP_HOST': 'seafile.kisiel.net.pl', 'HTTP_SCHEME': 'https', ...}, start_response=<wsgidav.util.SubAppStartResponse object>)
193 return self.sendBasicAuthResponse(environ, start_response)
194 elif authmethod == "basic" and self._acceptbasic:
=> 195 return self.authBasicAuthRequest(environ, start_response)
196
197 util.log("HTTPAuthenticator: respond with 400 Bad request; Auth-Method: %s" % authmethod)
self = <wsgidav.http_authenticator.HTTPAuthenticator object>, self.authBasicAuthRequest = <bound method HTTPAuthenticator.authBasicAuthReq...dav.http_authenticator.HTTPAuthenticator object>>, environ = {'CONTENT_LENGTH': '', 'CONTENT_TYPE': '', 'HTTPS': 'on', 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'HTTP_ACCEPT_ENCODING': 'gzip, deflate, br', 'HTTP_ACCEPT_LANGUAGE': 'en-US,en;q=0.5', 'HTTP_AUTHORIZATION': 'Basic YWRtaW5Aa2lzaWVsLm5ldC5wbDpwcmVkaWN0IHVuYWZyYWlkIHN1cnZpdm9yIGNoYWluIHdyZWNrYWdlIHB1cmlmaWVy', 'HTTP_CACHE_CONTROL': 'max-age=0', 'HTTP_HOST': 'seafile.kisiel.net.pl', 'HTTP_SCHEME': 'https', ...}, start_response = <wsgidav.util.SubAppStartResponse object>
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/wsgidav/http_authenticator.py in authBasicAuthRequest(self=<wsgidav.http_authenticator.HTTPAuthenticator object>, environ={'CONTENT_LENGTH': '', 'CONTENT_TYPE': '', 'HTTPS': 'on', 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'HTTP_ACCEPT_ENCODING': 'gzip, deflate, br', 'HTTP_ACCEPT_LANGUAGE': 'en-US,en;q=0.5', 'HTTP_AUTHORIZATION': 'Basic YWRtaW5Aa2lzaWVsLm5ldC5wbDpwcmVkaWN0IHVuYWZyYWlkIHN1cnZpdm9yIGNoYWluIHdyZWNrYWdlIHB1cmlmaWVy', 'HTTP_CACHE_CONTROL': 'max-age=0', 'HTTP_HOST': 'seafile.kisiel.net.pl', 'HTTP_SCHEME': 'https', ...}, start_response=<wsgidav.util.SubAppStartResponse object>)
236 environ["http_authenticator.realm"] = realmname
237 environ["http_authenticator.username"] = username
=> 238 return self._application(environ, start_response)
239 return self.sendBasicAuthResponse(environ, start_response)
240
self = <wsgidav.http_authenticator.HTTPAuthenticator object>, self._application = <wsgidav.dir_browser.WsgiDavDirBrowser object>, environ = {'CONTENT_LENGTH': '', 'CONTENT_TYPE': '', 'HTTPS': 'on', 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'HTTP_ACCEPT_ENCODING': 'gzip, deflate, br', 'HTTP_ACCEPT_LANGUAGE': 'en-US,en;q=0.5', 'HTTP_AUTHORIZATION': 'Basic YWRtaW5Aa2lzaWVsLm5ldC5wbDpwcmVkaWN0IHVuYWZyYWlkIHN1cnZpdm9yIGNoYWluIHdyZWNrYWdlIHB1cmlmaWVy', 'HTTP_CACHE_CONTROL': 'max-age=0', 'HTTP_HOST': 'seafile.kisiel.net.pl', 'HTTP_SCHEME': 'https', ...}, start_response = <wsgidav.util.SubAppStartResponse object>
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/wsgidav/dir_browser.py in __call__(self=<wsgidav.dir_browser.WsgiDavDirBrowser object>, environ={'CONTENT_LENGTH': '', 'CONTENT_TYPE': '', 'HTTPS': 'on', 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'HTTP_ACCEPT_ENCODING': 'gzip, deflate, br', 'HTTP_ACCEPT_LANGUAGE': 'en-US,en;q=0.5', 'HTTP_AUTHORIZATION': 'Basic YWRtaW5Aa2lzaWVsLm5ldC5wbDpwcmVkaWN0IHVuYWZyYWlkIHN1cnZpdm9yIGNoYWluIHdyZWNrYWdlIHB1cmlmaWVy', 'HTTP_CACHE_CONTROL': 'max-age=0', 'HTTP_HOST': 'seafile.kisiel.net.pl', 'HTTP_SCHEME': 'https', ...}, start_response=<wsgidav.util.SubAppStartResponse object>)
171 # # sort: 0:"calls",1:"time", 2: "cumulative"
172 # profile.print_stats(sort=2)
=> 173 return self._listDirectory(davres, environ, start_response)
174
175 return self._application(environ, start_response)
self = <wsgidav.dir_browser.WsgiDavDirBrowser object>, self._listDirectory = <bound method WsgiDavDirBrowser._listDirectory of <wsgidav.dir_browser.WsgiDavDirBrowser object>>, davres = RootResource('/'), environ = {'CONTENT_LENGTH': '', 'CONTENT_TYPE': '', 'HTTPS': 'on', 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'HTTP_ACCEPT_ENCODING': 'gzip, deflate, br', 'HTTP_ACCEPT_LANGUAGE': 'en-US,en;q=0.5', 'HTTP_AUTHORIZATION': 'Basic YWRtaW5Aa2lzaWVsLm5ldC5wbDpwcmVkaWN0IHVuYWZyYWlkIHN1cnZpdm9yIGNoYWluIHdyZWNrYWdlIHB1cmlmaWVy', 'HTTP_CACHE_CONTROL': 'max-age=0', 'HTTP_HOST': 'seafile.kisiel.net.pl', 'HTTP_SCHEME': 'https', ...}, start_response = <wsgidav.util.SubAppStartResponse object>
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/wsgidav/dir_browser.py in _listDirectory(self=<wsgidav.dir_browser.WsgiDavDirBrowser object>, davres=RootResource('/'), environ={'CONTENT_LENGTH': '', 'CONTENT_TYPE': '', 'HTTPS': 'on', 'HTTP_ACCEPT': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'HTTP_ACCEPT_ENCODING': 'gzip, deflate, br', 'HTTP_ACCEPT_LANGUAGE': 'en-US,en;q=0.5', 'HTTP_AUTHORIZATION': 'Basic YWRtaW5Aa2lzaWVsLm5ldC5wbDpwcmVkaWN0IHVuYWZyYWlkIHN1cnZpdm9yIGNoYWluIHdyZWNrYWdlIHB1cmlmaWVy', 'HTTP_CACHE_CONTROL': 'max-age=0', 'HTTP_HOST': 'seafile.kisiel.net.pl', 'HTTP_SCHEME': 'https', ...}, start_response=<wsgidav.util.SubAppStartResponse object>)
261 # No pre-build info: traverse members
262 dirInfoList = []
=> 263 childList = davres.getDescendants(depth="1", addSelf=False)
264 for res in childList:
265 di = res.getDisplayInfo()
childList undefined, davres = RootResource('/'), davres.getDescendants = <bound method RootResource.getDescendants of RootResource('/')>, depth undefined, addSelf undefined, builtin False = False
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/wsgidav/dav_provider.py in getDescendants(self=RootResource('/'), collections=True, resources=True, depthFirst=False, depth='1', addSelf=False)
445 res.append(self)
446 if depth != "0" and self.isCollection:
=> 447 for child in self.getMemberList():
448 if not child:
449 _ = self.getMemberList()
child undefined, self = RootResource('/'), self.getMemberList = <bound method RootResource.getMemberList of RootResource('/')>
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/wsgidav/addons/seafile/seafile_dav_provider.py in getMemberList(self=RootResource('/'))
494 if len(r_list) == 1:
495 repo = r_list[0]
=> 496 res = self._createRootRes(repo, repo.name)
497 member_list.append(res)
498 else:
res undefined, self = RootResource('/'), self._createRootRes = <bound method RootResource._createRootRes of RootResource('/')>, repo = <pysearpc.client._SearpcObj object>, repo.name = 'photos'
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/wsgidav/addons/seafile/seafile_dav_provider.py in _createRootRes(self=RootResource('/'), repo=<pysearpc.client._SearpcObj object>, name='photos')
505
506 def _createRootRes(self, repo, name):
=> 507 obj = get_repo_root_seafdir(repo)
508 return SeafDirResource("/"+name, repo, "", obj, self.environ)
509
obj undefined, global get_repo_root_seafdir = <function get_repo_root_seafdir>, repo = <pysearpc.client._SearpcObj object>
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/wsgidav/addons/seafile/seafile_dav_provider.py in get_repo_root_seafdir(repo=<pysearpc.client._SearpcObj object>)
618
619 def get_repo_root_seafdir(repo):
=> 620 root_id = commit_mgr.get_commit_root_id(repo.id, repo.version, repo.head_cmmt_id)
621 return fs_mgr.load_seafdir(repo.store_id, repo.version, root_id)
622
root_id undefined, global commit_mgr = <seafobj.commits.SeafCommitManager object>, commit_mgr.get_commit_root_id = <bound method SeafCommitManager.get_commit_root_id of <seafobj.commits.SeafCommitManager object>>, repo = <pysearpc.client._SearpcObj object>, repo.id = u'46584b3b-69bc-4380-9e4c-927d82b0022e', repo.version = 1, repo.head_cmmt_id = u'3c502857ec5a293b0819f83ac2ca804d4bdd09dd'
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/seafobj/commits.py in get_commit_root_id(self=<seafobj.commits.SeafCommitManager object>, repo_id=u'46584b3b-69bc-4380-9e4c-927d82b0022e', version=1, commit_id=u'3c502857ec5a293b0819f83ac2ca804d4bdd09dd')
55
56 def get_commit_root_id(self, repo_id, version, commit_id):
=> 57 commit = self.load_commit(repo_id, version, commit_id)
58 return commit.root_id
59
commit undefined, self = <seafobj.commits.SeafCommitManager object>, self.load_commit = <bound method SeafCommitManager.load_commit of <seafobj.commits.SeafCommitManager object>>, repo_id = u'46584b3b-69bc-4380-9e4c-927d82b0022e', version = 1, commit_id = u'3c502857ec5a293b0819f83ac2ca804d4bdd09dd'
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/seafobj/commits.py in load_commit(self=<seafobj.commits.SeafCommitManager object>, repo_id=u'46584b3b-69bc-4380-9e4c-927d82b0022e', version=1, obj_id=u'3c502857ec5a293b0819f83ac2ca804d4bdd09dd')
41 else:
42 data = self.obj_stores['__default__'].read_obj(repo_id, version, obj_id)
=> 43 return self.parse_commit(data)
44
45 def parse_commit(self, data):
self = <seafobj.commits.SeafCommitManager object>, self.parse_commit = <bound method SeafCommitManager.parse_commit of <seafobj.commits.SeafCommitManager object>>, data = ''
/mnt/mfs/sfroot/seafile-pro-server-6.3.4/seahub/thirdpart/seafobj/commits.py in parse_commit(self=<seafobj.commits.SeafCommitManager object>, data='')
44
=> 46 dict = json.loads(data)
47 d = {}
48 for k, v in dict.iteritems():
builtin dict = <type 'dict'>, global json = <module 'json' from '/usr/lib/python2.7/json/__init__.pyc'>, json.loads = <function loads>, data = ''
/usr/lib/python2.7/json/__init__.py in loads(s='', encoding=None, cls=None, object_hook=None, parse_float=None, parse_int=None, parse_constant=None, object_pairs_hook=None, **kw={})
337 parse_int is None and parse_float is None and
338 parse_constant is None and object_pairs_hook is None and not kw):
=> 339 return _default_decoder.decode(s)
340 if cls is None:
341 cls = JSONDecoder
global _default_decoder = <json.decoder.JSONDecoder object>, _default_decoder.decode = <bound method JSONDecoder.decode of <json.decoder.JSONDecoder object>>, s = ''
/usr/lib/python2.7/json/decoder.py in decode(self=<json.decoder.JSONDecoder object>, s='', _w=<built-in method match of _sre.SRE_Pattern object>)
362
363 """
=> 364 obj, end = self.raw_decode(s, idx=_w(s, 0).end())
365 end = _w(s, end).end()
366 if end != len(s):
obj undefined, end undefined, self = <json.decoder.JSONDecoder object>, self.raw_decode = <bound method JSONDecoder.raw_decode of <json.decoder.JSONDecoder object>>, s = '', idx undefined, _w = <built-in method match of _sre.SRE_Pattern object>, ).end undefined
/usr/lib/python2.7/json/decoder.py in raw_decode(self=<json.decoder.JSONDecoder object>, s='', idx=0)
379 try:
380 obj, end = self.scan_once(s, idx)
381 except StopIteration:
=> 382 raise ValueError("No JSON object could be decoded")
383 return obj, end
builtin ValueError = <type 'exceptions.ValueError'>
<type 'exceptions.ValueError'>: No JSON object could be decoded
args = ('No JSON object could be decoded',)
message = 'No JSON object could be decoded'
