I am new to Seafile, and only a casual home server user/admin/noob.
I have successfully followed the instructions for setting up Seafile CE via Docker on Ubuntu 20.04. I can access the web portal via a no-ip domain and sync to Windows via the client.
I am trying to setup FUSE as I want to be able to backup the actual files. Following the instructions here: https://manual.seafile.com/extension/fuse/#how-to-start-seaf-fuse-in-docker
My docker-compose yml:
version: '2.0'
db:
image: mariadb:10.5
container_name: seafile-mysql
- MYSQL_ROOT_PASSWORD=************* # Requested, set the root's password of MySQL service.
- MYSQL_LOG_CONSOLE=true
- /home/jonathan/seafile/seafile-mysql/db:/var/lib/mysql # Requested, specifies the path to MySQL data persistent store.
networks:
- seafile-net
memcached:
image: memcached:1.5.6
entrypoint: memcached -m 256
networks:
- seafile-net
seafile:
- "80:80"
- "443:443"
- /home/jonathan/seafile/seafile-data:/shared
- type: bind
source: /home/jonathan/seafile/seafile-fuse
target: /seafile-fuse
bind:
propagation: rshared
privileged: true
cap_add:
- SYS_ADMIN
- DB_HOST=db
- DB_ROOT_PASSWD=*************
- TIME_ZONE=*****
- SEAFILE_ADMIN_EMAIL=**********@gmail.com
- SEAFILE_ADMIN_PASSWORD=**************
- SEAFILE_SERVER_LETSENCRYPT=true
- SEAFILE_SERVER_HOSTNAME=*******.ddns.net
depends_on:
- db
- memcached
networks:
- seafile-net
networks:
seafile-net:
Leads to the following error:
ERROR: The Compose file './docker-compose.yml' is invalid because:
services.seafile.volumes contains an invalid type, it should be a string
Any assistance please?
