OnlyOffice integration and external exposure
I have Seafile Server installed in a docker environment, works great. The subdomain I use for that is secured with SSL and HSTS.
I have OnlyOffice installed as well, solely for the purpose of editing office files in the Seafile environment. I have setup the link from Seafile to connect to the OnlyOffice server (running in docker). This is working well.
I am using Nginx Proxy Manager to manage the secure forwarding of subdomains. Both the Seafile and OnlyOffice subdomains are configured to point to the correct server at the backend. In Nginx Proxy Manager I have for both subdomains SSL certificates.
Everything is working, until I switch on HSTS on the OnlyOffice subdomain in the Nginx Proxy Manager. Then, whenever I open an office document in Seafile, I will have a message: “To protect your security, [onlyoffice subdomain] will not allow Firefox to display the page if another site has embedded it.”
Any clue why this is the case, and what I can do to fix this? Seems to be that the option ‘X-Frame-Options’ to ‘sameorigin’ may be the reason why Firefox does not allow it.
Another way I guess is that I may have to move to a direct Nginx environment to get more configuration options.
You can run your site through https://securityheaders.com to confirm if it has the X-Frame-Options headers already. Or you can see that if you load the site, hit F12, go to network tab, F5 to refresh the site, click on one of the items here with a “status” of 200, and look at the headers on the right side.
I’m no expert, but I believe this same message can also happen because of the settings in the content-security-policy header.
In nginx, you would add those with lines like:
add_header X-Frame-Options "SAMEORIGIN";
add_header Content-Security-Policy "default-src";
I don’t know anything about npm, but there’s probably a place in there to put in nginx config options to have it build them into the nginx config it generates.
I am indeed trying to secure the onlyoffice subdomain, and using security headers to check the situation. And indeed the solution lies in the correct configuration of the Nginx Proxy Manager (NPM) reverse proxy.
I am running the onlyoffice service on another subdomain. Within Seafile, document preview is done by loading onlyoffice inside a frame within the seafile subdomain, so setting The X-Frame-Options "SAMEORIGIN" will mess that up. And unfortunately NPM is not so evident to get this fixed.
I got it working using NPM, security headers now give A+ and previews are working as expected!
Since there may be more people running Seafile with OnlyOffice both on their own subdomain behind NPM as reverse proxy. Assuming integration between the two works, but you’re not getting the A+ security headers, NPM is the culprit, and this is what I’ve done. I got it working with information from these NPM discussions:
[How to use 'Custom Nginx Configuration' function to modify headers for added security · Issue #582 · NginxProxyManager/nginx-proxy-manager · GitHub]
And especially the last post in the following discussion:
[Workaround - Security Headers @ NGINX Proxy Manager · GitHub]
In NPM for the proxy host for the onlyoffice subdomain, I switched off the ‘toggle’ for HSTS and added the security headers manually by adding a custom location ‘/’ and add the headers directly under advanced configuration, explicitly removing
and adding the following line (I’ve changed the source to seafile.example.com her below, but obviously you should put the source to be the Seafile subdomain, since that is the calling parent):
add_header Content-Security-Policy "frame-ancestors https://seafile.example.com 'self'";
So for that specific proxy with NPM the custom location looks like this:
The HSTS toggles are no longer needed, since we will add this ourself manually as below (leaving the toggle on will give duplicate entries in the header which may mess up a browser (you get warnings on securityheaders.com for this)
And the advanced configuration is as follows (change frame-ancestors to reflect your seafile subdomain!):
add_header Strict-Transport-Security "max-age=15552000; includeSubDomains; preload" always;
add_header Referrer-Policy strict-origin-when-cross-origin;
add_header X-Content-Type-Options nosniff;
add_header X-XSS-Protection "1; mode=block";
add_header Content-Security-Policy upgrade-insecure-requests;
add_header Permissions-Policy interest-cohort=();
add_header Expect-CT 'enforce; max-age=604800';
more_set_headers 'Server: Proxy';
more_clear_headers 'X-Powered-By';
Would you mind sharing some more details for your setup? I’ve been trying to get OnlyOffice and Seafile integration on my server but haven’t had any luck. Every time I open a document in Seafile it loads a blank white screen.
I also use NPM for my reverse proxy.
Hi! Sorry for this late reply. I am not frequently visiting the forum.
One thing I have done to make OnlyOffice integrate with Seafile is to also add a (https) available via NPM, so, OnlyOffice is also accessable from the outside. After I did that I was able to get it working.
I am not sure if you have found a solution already, but if you are still trying to get it working, I can dive a bit deeper into my setup. As with most of my stuff, I have it set and forget (of course with keeping things up to date).
I was able to get it working thankfully. I don’t remember what my original issue was, but getting my SSL certs copied over from NPM to only office was definitely needed. I wasn’t able to get it to work over http on my LAN.
Even though I struggled quite a bit the documentation is actually pretty good and I think it covered everything required.
Not really. As @faethon said, you can proxy OO as well; that way the TLS termination is done by the reverse proxy and you don’t have to configure OO itself to do it.
It’s been a bit since I did it, so I may not remember perfectly, but it might be because I’m running an unRAID server and the way my specific only office docker image is built, but copying the certs over was the only way I was able to get it to work.
Although it would be nicer if I didn’t have to copy certs over, since everything is working I’m inclined to leave it as is, until something breaks.
Running it on unraid as well; listed as OnlyOfficeDocumentServer in unraid apps (template uses onlyoffice/documentserver image).
My CSP hdr for onlyoffice subdomain is
add_header Content-Security-Policy "upgrade-insecure-requests; frame-ancestors 'self' mydomain.eu *.mydomain.eu" always;
I’m using the same docker image you are. The template instructions say:
HTTPS Support can be enable creating a “certs” folder in the data directory and placing onlyoffice.crt and onlyoffice.key in it.
From what I recall, before I copied the certs NPM generated over I wasn’t able to access onlyoffice.mydomain.com externally, nor did the seafile-onlyoffice integration work right.
I tried reconfiguring my setup to follow @faethon directions but I’m doing something wrong and can’t get it to work. As luck would have it, when I reverted my changes it stayed broken :upside_down_face:.
What does your seahub_settings.py look like? Is the ONLYOFFICE_APIJS_URL set to a local ip, or is it onlyoffice.mydomain.com?
Need to get reacquainted with the instructions, but the general premise of a reverse proxy such as nginx is that it does the SSL termination, meaning all the services behind it (such as onlyoffice or seafile) won’t deal with it in any manner whatsoever. This means both my seafile & onlyoffice services themselves are exposed only over http – it’s just the proxy that deals with https.
Most of my seahub_settings.py:
SECRET_KEY = 'mysecret-redacted'
DATABASES = {
    'default': {
        'NAME': 'seahub_db',
        'USER': 'db-user',
        'PASSWORD': 'db-pass',
        'HOST': 'mysql-db',
        'PORT': '3306'
ENABLE_SIGNUP = False
ACTIVATE_AFTER_REGISTRATION = False
FILE_SERVER_ROOT = 'https://seafile.mydomain.eu/seafhttp'
ENABLE_THUMBNAIL = True
CACHES = {
    'default': {
        'LOCATION': 'memcached:11211',
    'locmem': {
# Enable Only Office
ENABLE_ONLYOFFICE = True
VERIFY_ONLYOFFICE_CERTIFICATE = True
ONLYOFFICE_APIJS_URL = 'https://onlyoffice.mydomain.eu/web-apps/apps/api/documents/api.js'
ONLYOFFICE_FILE_EXTENSION = ('doc', 'docx', 'ppt', 'pptx', 'xls', 'xlsx', 'odt', 'fodt', 'odp', 'fodp', 'ods', 'fods')
ONLYOFFICE_EDIT_FILE_EXTENSION = ('docx', 'pptx', 'xlsx')
ONLYOFFICE_JWT_SECRET = 'onlyoffice-jwt-secret-redacted'
SERVICE_URL = 'https://seafile.mydomain.eu'
# needed as of seafile v11 that uses django 4; see https://manual.seafile.com/11.0/upgrade/upgrade_notes_for_11.0.x/#django-csrf-protection-issue :
CSRF_TRUSTED_ORIGINS = [SERVICE_URL]
