Possible bug in seafile 12.06 thumbnail generation
Here is the second in my series of possible bugs when upgrading from Seafile 11 to Seafile 12.
When clicking through the web interface and going from directory to directory, there were several that triggered these errors in the logs:
[2024-12-23 14:50:41] [INFO] start to serve on pipe client
2024-12-23 14:50:41,595 [ERROR] seahub.thumbnail.utils:211 pdf_bytes_to_images [Errno 2] No such file or directory: 'pdftoppm'
2024-12-23 14:50:41,597 [ERROR] seahub.thumbnail.utils:239 create_pdf_thumbnails [Errno 2] No such file or directory: '/tmp/c10c889d.png'
2024-12-23 14:50:41,598 [ERROR] django.request:241 log_response Internal Server Error: /thumbnail/1b9b2a8a-22bb-40e5-991d-48b2dfa305ac/create/
  File "/opt/seafile/seafile-server-12.0.6/seahub/seahub/thumbnail/utils.py", line 235, in create_pdf_thumbnails
    ret = _create_thumbnail_common(tmp_path, thumbnail_file, size)
  File "/opt/seafile/seafile-server-12.0.6/seahub/seahub/thumbnail/utils.py", line 278, in _create_thumbnail_common
    image = Image.open(fp)
  File "/usr/local/lib/python3.12/dist-packages/PIL/Image.py", line 3431, in open
    fp = builtins.open(filename, "rb")
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/c10c889d.png'
  File "/opt/seafile/seafile-server-12.0.6/seahub/thirdpart/django/core/handlers/exception.py", line 55, in inner
  File "/opt/seafile/seafile-server-12.0.6/seahub/thirdpart/django/core/handlers/base.py", line 197, in _get_response
  File "/opt/seafile/seafile-server-12.0.6/seahub/seahub/auth/decorators.py", line 69, in _wrapped_view
  File "/opt/seafile/seafile-server-12.0.6/seahub/seahub/thumbnail/views.py", line 59, in thumbnail_create
    success, status_code = generate_thumbnail(request, repo_id, size, path)
  File "/opt/seafile/seafile-server-12.0.6/seahub/seahub/thumbnail/utils.py", line 129, in generate_thumbnail
    return create_pdf_thumbnails(repo, file_id, path, size,
  File "/opt/seafile/seafile-server-12.0.6/seahub/seahub/thumbnail/utils.py", line 240, in create_pdf_thumbnails
    os.unlink(tmp_path)
I noticed the same errors. The seafileltd/seafile-mc:12.0-latest container (sha256:c07a22ae7cf9c5274fc8d4fe15734c497550ce1bd5b9758cf169e1a18fc6797b) seems to be missing the poppler-utils package.
I manually installed it via apt install poppler-utils (which will be gone after container restart ofc) and this fixed it. PDF preview images are generated – which become file icons
Edit: Already fixed upstream in GitHub: 12.0 ce add poppler-utils by SkywalkerSpace · Pull Request #432 · haiwen/seafile-docker · GitHub
Same issue, but I installed Seafile from binaries. Installing poppler-utils didn’t make any difference.
[2025-05-20 12:19:07] [ERROR] seahub.thumbnail.utils:211 pdf_bytes_to_images Command '['pdftoppm', '-png', '-r', '200', '-f', '1', '-l', '1', '-singlefile', '/tmp/tmpg70zj5n7.pdf', '-o', '/tmp/58b40efb']' returned non-zero exit status 1.
