seafile | *** Booting runit daemon...
seafile | *** Runit started as PID 27
seafile | *** Running /scripts/start.py...
seafile | [05/30/2020 12:07:46][upgrade]: The container was recreated, running minor-upgrade.sh to fix the media symlinks
seafile | [05/30/2020 12:07:46][upgrade]: Running script /opt/seafile/seafile-pro-server-7.1.3/upgrade/minor-upgrade.sh
seafile | [2020-05-30 12:07:46] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.
seafile | File "/scripts/start.py", line 86, in <module>
seafile | main()
seafile | File "/scripts/start.py", line 58, in main
seafile | check_upgrade()
seafile | File "/scripts/upgrade.py", line 169, in check_upgrade
seafile | fix_media_symlinks(current_version)
seafile | File "/scripts/upgrade.py", line 80, in fix_media_symlinks
seafile | run_minor_upgrade(current_version)
seafile | File "/scripts/upgrade.py", line 84, in run_minor_upgrade
seafile | run_script_and_update_version_stamp(minor_upgrade_script, current_version)
seafile | File "/scripts/upgrade.py", line 60, in run_script_and_update_version_stamp
seafile | replace_file_pattern(script, 'read dummy', '')
seafile | File "/scripts/utils/__init__.py", line 295, in replace_file_pattern
seafile | with open(fn, 'r') as fp:
seafile | FileNotFoundError: [Errno 2] No such file or directory: '/opt/seafile/seafile-pro-server-7.1.3/upgrade/minor-upgrade.sh'
seafile | *** /scripts/start.py exited with status 1.
seafile | *** Shutting down runit daemon (PID 27)...
seafile | *** Running /etc/my_init.post_shutdown.d/10_syslog-ng.shutdown...
seafile | *** Killing all processes...
Let me ask once again - Don’t you, guys, need someone to help you with docker build?
