I can import old wikis using the “Convert to new wiki” menu option. When I select this, I get an error message after entering the wiki name, but it only consists of an exclamation mark. However, I find the following information in the seafile.log file:
[2025-12-15 16:18:17] [WARNING] repo-op.c(314): parent_dir /wiki-pages doesn’t exist in repo ad68b91b-e2c7-4083-8617-c88926a7f276.
[2025-12-15 16:18:19] [WARNING] repo-op.c(314): parent_dir /_Internal doesn’t exist in repo ad68b91b-e2c7-4083-8617-c88926a7f276.
What’s the problem?
When I click on the newly created wiki this way, I see wiki pages displayed on the left, but it’s likely not all of them. How can I check this?
Furthermore, no images were transferred; there are only placeholders with instructions to download and insert the image. There isn’t even a reference to the image filename. The images are stored under /seahub-data/custom. They are PNG images, 8-bit/color RGB or RGBA.
It also seems to me that the links were copied verbatim. Shouldn’t they be changed? The links point to the old wiki; once that’s deleted, they won’t work anymore. At least, that’s what I assume.
I imagine converting to the new wiki should work differently.
The menu item “Convert to new wiki” is only available if I created the old wiki myself. I can’t convert other wikis, even if I have read and write permissions. Even if I transfer the ownership of the library to me, this option is missing from the menu. What else is needed?
One more thing: as long as a wiki only has a single page, it cannot be deleted. Is this intentional?
