After the update the S drive is still available, but not linked to SeaDrive. When I start SeaDrive it asks me to assign another drive letter.
I did that and then SeaDrive crashed. I started it up again and then it asks me to assign another letter. The previous assigned letter cannot be chosen anylonger.
What could be the issue?
Logs:
[06/10/17 07:12:16] Seadrive daemon process crashed with code -1073741819
[06/10/17 07:12:16] Exiting with error: SeaDrive exited unexpectedly
[06/10/17 07:12:16] failed to get seadrive.events: ‘[’ or ‘{’ expected near end of file
[06/10/17 07:12:16] failed to get global sync status:
[06/10/17 07:12:16] failed to get sync errors: ‘[’ or ‘{’ expected near ‘failed’
[06/10/17 07:12:16] SeaDrive exited unexpectedly
[06/10/17 07:12:16] app event loop exited with 1
[06/10/17 07:12:16] Unmounting before exit
[06/10/17 07:12:16] [Daemon Mgr] stopping seadrive daemon
[06/10/17 07:13:04] loaded 1 accounts
[06/10/17 07:13:04] seadrive gui started
[06/10/17 07:13:04] disk letter not set or set but not available
[06/10/17 07:13:16] Exiting with error: Faild to choose a disk letter
[06/10/17 07:13:17] Faild to choose a disk letter
[06/10/17 07:13:17] app event loop exited with 1
[06/10/17 07:13:17] Not unmounting because rpc client not ready.
[06/10/17 07:13:17] [Daemon Mgr] stopping seadrive daemon
[06/10/17 08:55:56] loaded 1 accounts
[06/10/17 08:55:56] seadrive gui started
[06/10/17 08:55:56] disk letter not set or set but not available
[06/10/17 08:56:07] starting seadrive daemon: seadrive.exe “-d” “C://seadrive/data" “-l” "C://seadrive/logs/seadrive.log” “J:”
[06/10/17 08:56:10] Unable to get config value download_limit: Config not exists
[06/10/17 08:56:10] Unable to get config value upload_limit: Config not exists
[06/10/17 08:56:10] Switched to account http://*
[06/10/17 09:02:42] Seadrive daemon process crashed with code -1073741819
[06/10/17 09:02:42] Exiting with error: SeaDrive exited unexpectedly
[06/10/17 09:02:43] failed to get global sync status:
[06/10/17 09:02:43] failed to get sync errors: unable to decode byte 0xc0
[06/10/17 09:02:44] failed to get global sync status:
[06/10/17 09:02:44] failed to get sync errors: ‘[’ or ‘{’ expected near ‘failed’
[06/10/17 09:02:45] failed to get global sync status:
[06/10/17 09:02:45] failed to get sync errors: unable to decode byte 0xa0
[06/10/17 09:02:46] failed to get global sync status:
[06/10/17 09:02:46] failed to get sync errors: ‘[’ or ‘{’ expected near ‘failed’
[06/10/17 09:02:47] failed to get global sync status:
[06/10/17 09:02:48] failed to get global sync status:
[06/10/17 09:02:48] failed to get sync errors: ‘[’ or ‘{’ expected near ‘failed’
[06/10/17 09:02:49] SeaDrive exited unexpectedly
[06/10/17 09:02:49] app event loop exited with 1
[06/10/17 09:02:49] Unmounting before exit
[06/10/17 09:02:49] [Daemon Mgr] stopping seadrive daemon
[06/10/17 09:04:56] loaded 1 accounts
[06/10/17 09:04:56] seadrive gui started
[06/10/17 09:04:56] disk letter not set or set but not available
[06/10/17 09:06:06] starting seadrive daemon: seadrive.exe “-d” “C://seadrive/data" “-l” "C://seadrive/logs/seadrive.log” “K:”
[06/10/17 09:06:09] Unable to get config value download_limit: Config not exists
[06/10/17 09:06:09] Unable to get config value upload_limit: Config not exists
[06/10/17 09:06:09] Switched to account http://*
[06/10/17 09:06:26] Seadrive daemon process crashed with code -1073741819
[06/10/17 09:06:26] Exiting with error: SeaDrive exited unexpectedly
[06/10/17 09:06:27] failed to get global sync status:
[06/10/17 09:06:27] failed to get sync errors: unable to decode byte 0xf0
[06/10/17 09:06:28] SeaDrive exited unexpectedly
[06/10/17 09:06:28] app event loop exited with 1
[06/10/17 09:06:28] Unmounting before exit
[06/10/17 09:06:28] [Daemon Mgr] stopping seadrive daemon
[06/10/17 09:09:48] loaded 1 accounts
[06/10/17 09:09:48] seadrive gui started
[06/10/17 09:09:48] disk letter not set or set but not available
[06/10/17 09:09:51] starting seadrive daemon: seadrive.exe “-d” “C://seadrive/data" “-l” "C://seadrive/logs/seadrive.log” “L:”
[06/10/17 09:09:54] Unable to get config value download_limit: Config not exists
[06/10/17 09:09:54] Unable to get config value upload_limit: Config not exists
[06/10/17 09:09:54] Switched to account http://* *
[06/10/17 09:50:38] Seadrive daemon process crashed with code -1073741819
[06/10/17 09:50:38] Exiting with error: SeaDrive exited unexpectedly
[06/10/17 09:50:38] failed to get sync notification: premature end of input
[06/10/17 09:50:38] failed to get global sync status: end of file expected near end of file
[06/10/17 09:50:38] failed to get sync errors: ‘[’ or ‘{’ expected near ‘&’
[06/10/17 09:50:39] failed to get seadrive.events: end of file expected near end of file
[06/10/17 09:50:39] failed to get sync notification: premature end of input
[06/10/17 09:50:39] failed to get global sync status: ‘[’ or ‘{’ expected near ‘’
[06/10/17 09:50:39] failed to get sync errors: unable to decode byte 0xc0
[06/10/17 09:50:40] failed to get seadrive.events: ‘[’ or ‘{’ expected near ‘’
[06/10/17 09:50:40] failed to get sync notification: ‘[’ or ‘{’ expected near end of file
[06/10/17 09:50:40] failed to get global sync status: ‘[’ or ‘{’ expected near end of file
[06/10/17 09:50:40] failed to get sync errors: ‘[’ or ‘{’ expected near ‘|’
[06/10/17 09:50:40] SeaDrive exited unexpectedly
[06/10/17 09:50:40] app event loop exited with 1
[06/10/17 09:50:40] Unmounting before exit
[06/10/17 09:50:40] [Daemon Mgr] stopping seadrive daemon
[06/10/17 09:51:28] loaded 1 accounts
[06/10/17 09:51:28] seadrive gui started
[06/10/17 09:51:28] disk letter not set or set but not available
[06/10/17 09:51:30] starting seadrive daemon: seadrive.exe “-d” “C://seadrive/data" “-l” "C://seadrive/logs/seadrive.log” “M:”
[06/10/17 09:51:33] Unable to get config value download_limit: Config not exists
[06/10/17 09:51:33] Unable to get config value upload_limit: Config not exists
[06/10/17 09:51:33] Switched to account http://*
