Hi
I’ve got installed a seafile server on my vps (debian 9 / yunohost server / yunohost appl. seafile)
This server is update and works fine with Linux clients under Debian.
But I’ve got a problem with my freeBSD client
I’ ve installed it with pkg
seafile-gui-7.0.7
Version : 7.0.7
Installed on : Fri Apr 24 21:53:53 2020 CEST
Origin : net-mgmt/seafile-gui
Architecture : FreeBSD:12:amd64
Prefix : /usr/local
Categories : devel net-mgmt
Licenses : APACHE20
Maintainer :
WWW :
Comment : Open Source Cloud Storage (Client)
Options :
DEBUG : off
NLS : on
Shared Libs required:
libglib-2.0.so.0
libQt5Gui.so.5
libgobject-2.0.so.0
libQt5Core.so.5
libseafile.so.0
libQt5DBus.so.5
libsqlite3.so.0
libQt5Widgets.so.5
libQt5Network.so.5
libsearpc.so.1
libintl.so.8
libevent-2.1.so.7
libgio-2.0.so.0
libjansson.so.4
Annotations :
FreeBSD_version: 1201000
repo_type : binary
repository : FreeBSD
Flat size : 3.36MiB
But works only one time; after the CPU increase and increase. Something tje upload works still 30% and failed.
Here the top
PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND
16388 ragnarok 14 20 0 95M 30M kqread 1 24:49 298.64% seaf-dae
1635 ragnarok 3 21 0 97M 56M select 0 3:46 2.39% Xorg
And a copy of seafile.log client
cat .ccnet/logs/seafile.log | tail -20
[04/25/20 11:13:30] http-tx-mgr.c(945): libcurl failed to PUT XXXXseafhttp/repo/c67ee548-06d9-4046-82c3-61fe91a263b6/block/9175d6b8f2d12d204fc9eb558a3ab77abfb43815: Stream error in the HTTP/2 framing layer.
[04/25/20 11:13:32] http-tx-mgr.c(945): libcurl failed to PUT XXXseafhttp/repo/c67ee548-06d9-4046-82c3-61fe91a263b6/block/a2eb87ce338abed1464788b57c848d480e260022: Stream error in the HTTP/2 framing layer.
[04/25/20 11:13:32] http-tx-mgr.c(1173): Transfer repo 'c67ee548': ('normal', 'data') --> ('error', 'finished')
[04/25/20 11:13:32] sync-mgr.c(621): Repo 'Seafile' sync state transition from uploading to 'error': 'Network error'.
[04/25/20 11:13:33] sync-mgr.c(582): Repo 'Seafile' sync state transition from 'synchronized' to 'uploading'.
[04/25/20 11:13:33] http-tx-mgr.c(1173): Transfer repo 'c67ee548': ('normal', 'init') --> ('normal', 'check')
[04/25/20 11:13:33] http-tx-mgr.c(1173): Transfer repo 'c67ee548': ('normal', 'check') --> ('normal', 'commit')
[04/25/20 11:13:33] http-tx-mgr.c(1173): Transfer repo 'c67ee548': ('normal', 'commit') --> ('normal', 'fs')
[04/25/20 11:13:33] http-tx-mgr.c(1173): Transfer repo 'c67ee548': ('normal', 'fs') --> ('normal', 'data')
[04/25/20 11:14:39] http-tx-mgr.c(945): libcurl failed to PUT XXXXX/repo/c67ee548-06d9-4046-82c3-61fe91a263b6/block/9175d6b8f2d12d204fc9eb558a3ab77abfb43815: Stream error in the HTTP/2 framing layer.
[04/25/20 11:14:39] http-tx-mgr.c(945): libcurl failed to PUT XXXXX/c67ee548-06d9-4046-82c3-61fe91a263b6/block/43c76b863d97f343afe309a5419a2302f78a3646: Operation was aborted by an application callback.
[04/25/20 11:14:40] http-tx-mgr.c(945): libcurl failed to PUT XXXX/repo/c67ee548-06d9-4046-82c3-61fe91a263b6/block/5faa66f6bf8ee3f5e33e691a5651cca676dad66a: Stream error in the HTTP/2 framing layer.
[04/25/20 11:14:43] http-tx-mgr.c(945): libcurl failed to PUTXXX/repo/c67ee548-06d9-4046-82c3-61fe91a263b6/block/a2eb87ce338abed1464788b57c848d480e260022: Stream error in the HTTP/2 framing layer.
[04/25/20 11:14:43] http-tx-mgr.c(1173): Transfer repo 'c67ee548': ('normal', 'data') --> ('error', 'finished')
[04/25/20 11:14:43] sync-mgr.c(621): Repo 'Seafile' sync state transition from uploading to 'error': 'Network error'.
[04/25/20 11:14:44] sync-mgr.c(582): Repo 'Seafile' sync state transition from 'synchronized' to 'uploading'.
[04/25/20 11:14:44] http-tx-mgr.c(1173): Transfer repo 'c67ee548': ('normal', 'init') --> ('normal', 'check')
[04/25/20 11:14:44] http-tx-mgr.c(1173): Transfer repo 'c67ee548': ('normal', 'check') --> ('normal', 'commit')
[04/25/20 11:14:44] http-tx-mgr.c(1173): Transfer repo 'c67ee548': ('normal', 'commit') --> ('normal', 'fs')
[04/25/20 11:14:44] http-tx-mgr.c(1173): Transfer repo 'c67ee548': ('normal', 'fs') --> ('normal', 'data')
And the log of the applet
[25.04.2020 11:01:32]id file not found, creating it
[25.04.2020 11:01:32]generated new device id 9e63fd18242356fdcfe89992edc32453d98df6e0
[25.04.2020 11:01:32]client id is 9e63fd18242356fdcfe89992edc32453d98df6e0
[25.04.2020 11:01:32]starting seaf-daemon: ("-c", "/home/ragnarok/.ccnet", "-d", "/home/ragnarok/Seafile/.seafile-data", "-w", "/home/ragnarok/Seafile")
[25.04.2020 11:01:32]daemon mgr: init => starting
[25.04.2020 11:01:32]seafile daemon is now running, checking if the service is ready
[25.04.2020 11:01:32]daemon mgr: starting => connecting
[25.04.2020 11:01:33][Rpc Client] connected to daemon
[25.04.2020 11:01:33]seaf daemon is ready
[25.04.2020 11:01:33]daemon mgr: connecting => connected
[25.04.2020 11:01:34]Starting the network status detector
[25.04.2020 11:01:34][AutoUpdateManager] cancel all download tasks
[25.04.2020 11:01:34][AutoUpdateManager] clean file caches db
[25.04.2020 11:01:34][AutoUpdateManager] removing cached files
[25.04.2020 11:01:34]starting applet rpc service
[25.04.2020 11:01:34]applet rpc service started
[25.04.2020 11:02:01]ServerStatusService: ignore request for host "XXXX"
[25.04.2020 11:02:01]ServerStatusService: ignore request for host "XXXXX"
[25.04.2020 11:02:01][Rpc Client] connected to daemon
[25.04.2020 11:02:02]libpng warning: iCCP: known incorrect sRGB profile
[25.04.2020 11:02:02]libpng warning: known incorrect sRGB profile
[25.04.2020 11:02:02]libpng warning: profile matches sRGB but writing iCCP instead
If anyone had an idea, I really need a BSD client
(I ve replace he link to my domain names by XXXXX if not I can’t post the log)
