version seafile 10. I don’t understand what the problem could be. The ngenix config was taken from the official website. The coolest thing is that the client on Windows and Android works fine, sometimes there are only problems with downloading files. and also before I started using ngenix. I still have the browser cache as I believe. and the page on one device worked fine on which I downloaded the seafile before ngenix. problems were discovered on another device and after clearing the cache.
listen 800;
server_name zomb;
proxy_read_timeout 1200s;
proxy_request_buffering off;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
root /home/direkt/osnovahdd/cloud/seafile-server-latest;
Please help me.
I’m assuming this is an NGINX instance running on your host machine and you are trying to reverse-proxy to Seafile running in docker, right?
In that case, you are duplicating too much stuff. The flow should actually be:
NGINX (host) → NGINX (seafile container) → Seahub
Something like this should work:
listen 800;
server_name zomb;
# set upstream location of seafile container
# doing it this way means NGINX will still start even if seafile container is not running
set $upstream_seafile http://127.0.0.1:8000;
proxy_http_version 1.1;
proxy_pass $upstream_seafile;
The advantage here is that you are just setting headers and letting the in-container NGINX do all the work. This configuration should work regardless of if the container is updated, so it saves you having to change things on upgrade.
In addition, you can easily add HTTPS to this configuration without having to load any certificates in the seafile container
Let me know if this helps or if I totally misunderstood your question/set-up.
oh god thank you so much it helped me but I changed the config a little.
listen 800;
server_name zomb;
Is this config correct?
I also use seafile not installed via a docker container. I also have a separate server with ngenix proxy manager which redirects from URL to 192.168.0.119:800
and receives an https certificate. Can I have problems with access speed and excessive buffering when downloading files? If so, how can I disable it?
