I just set up Seafile 9.0.10 CE on Debian 11 and when trying to login to Seahub it says:
Page unavailable
And seahub.log contains:
2023-02-13 23:19:57,458 [ERROR] django.request:224 log_response Internal Server Error: /accounts/login/
File "/opt/seafile/seafile-server-9.0.10/seafile/lib/python3/site-packages/pysearpc/named_pipe.py", line 85, in _get_transport
transport = self._pool.get(False)
File "/usr/lib/python3.9/queue.py", line 168, in get
raise Empty
_queue.Empty
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/core/handlers/exception.py", line 47, in inner
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/core/handlers/base.py", line 181, in _get_response
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/utils/decorators.py", line 130, in _wrapped_view
response = view_func(request, *args, **kwargs)
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/views/decorators/cache.py", line 44, in _wrapped_view_func
File "/opt/seafile/seafile-server-9.0.10/seahub/seahub/auth/views.py", line 123, in login
if form.is_valid():
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/forms/forms.py", line 175, in is_valid
return self.is_bound and not self.errors
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/forms/forms.py", line 170, in errors
self.full_clean()
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/forms/forms.py", line 373, in full_clean
self._clean_form()
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/forms/forms.py", line 400, in _clean_form
cleaned_data = self.clean()
File "/opt/seafile/seafile-server-9.0.10/seahub/seahub/auth/forms.py", line 61, in clean
self.user_cache = authenticate(username=username,
File "/opt/seafile/seafile-server-9.0.10/seahub/seahub/auth/__init__.py", line 56, in authenticate
user = backend.authenticate(**credentials)
File "/opt/seafile/seafile-server-9.0.10/seahub/seahub/base/accounts.py", line 578, in authenticate
user = self.get_user(username)
File "/opt/seafile/seafile-server-9.0.10/seahub/seahub/base/accounts.py", line 572, in get_user
user = self.get_user_with_import(username)
File "/opt/seafile/seafile-server-9.0.10/seahub/seahub/base/accounts.py", line 543, in get_user_with_import
emailuser = ccnet_api.get_emailuser_with_import(username)
File "/opt/seafile/seafile-server-9.0.10/seafile/lib/python3/site-packages/seaserv/api.py", line 902, in get_emailuser_with_import
return ccnet_threaded_rpc.get_emailuser_with_import(email)
File "/opt/seafile/seafile-server-9.0.10/seafile/lib/python3/site-packages/pysearpc/client.py", line 125, in newfunc
File "/opt/seafile/seafile-server-9.0.10/seafile/lib/python3/site-packages/pysearpc/named_pipe.py", line 97, in call_remote_func_sync
transport = self._get_transport()
File "/opt/seafile/seafile-server-9.0.10/seafile/lib/python3/site-packages/pysearpc/named_pipe.py", line 87, in _get_transport
transport = self._create_transport()
File "/opt/seafile/seafile-server-9.0.10/seafile/lib/python3/site-packages/pysearpc/named_pipe.py", line 80, in _create_transport
transport.connect()
File "/opt/seafile/seafile-server-9.0.10/seafile/lib/python3/site-packages/pysearpc/named_pipe.py", line 44, in connect
self.pipe.connect(self.socket_path)
ConnectionRefusedError: [Errno 111] Connection refused
And when I try to run ./reset-admin.sh I get the output:
/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/requests/__init__.py:102: RequestsDependencyWarning: urllib3 (1.26.13) or chardet (5.0.0)/charset_normalizer (2.0.12) doesn't match a supported version!
warnings.warn("urllib3 ({}) or chardet ({})/charset_normalizer ({}) doesn't match a supported "
raise Empty
_queue.Empty
File "/opt/seafile/seafile-server-9.0.10/seahub/manage.py", line 10, in <module>
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/core/management/__init__.py", line 419, in execute_from_command_line
utility.execute()
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/core/management/__init__.py", line 413, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/core/management/base.py", line 354, in run_from_argv
self.execute(*args, **cmd_options)
File "/opt/seafile/seafile-server-9.0.10/seahub/thirdpart/django/core/management/base.py", line 398, in execute
output = self.handle(*args, **options)
File "/opt/seafile/seafile-server-9.0.10/seahub/seahub/base/management/commands/createsuperuser.py", line 88, in handle
User.objects.get(email=default_username)
File "/opt/seafile/seafile-server-9.0.10/seahub/seahub/base/accounts.py", line 95, in get
emailuser = ccnet_threaded_rpc.get_emailuser(email)
transport.connect()
