Qnap container station
Hi
has anyone managed to install seafile with docker on qnap container station?
I am not sure how to work with more than the yaml file?
Yes, it worked, it works great, but why work with Container Station if it’s easier to log in via SSH and use regular Docker Compose?
Hi
Thanks a lot for getting back to me.
I thought it would be easier to maintain several docker images, when using container station.
If it worked for you, that sounds great.
Could you help me with the very first step, meaning how to start off in container station with the first Seafile Docker files?
I can only see the possibility for a sibgle yaml file in Container station.
The seafile in the documentation is broken down into separate services. Container Station can’t do this. That’s why I had to compile everything into one big docker-compose and manually define all the variables. I can give you my docker-compose; you just substitute your paths and variables and then feed it to Container Station.
That would be great.
I can use it as a template to understand the process and requirements better.
If will send you a private message.
Or could it just be pasted here in public?
Here is an example for Qnap with some comments, you just need to substitute your values
Thank you so much, this is great.
I hope I will get to try it out very quickly.
I will keep you posted.
Thanks again!
