Hi everyone,
I’m trying to migrate from my docker swarm seafile 7.1.5 to 8.0.3 but I’m having some kind of problem with seahub. I suppose it is related with my Dockerfile but who knows. Any help.
Dockerfile for 7.1.5:
Dockerfile for 8.0.3:
FROM phusion/baseimage:master-arm
RUN apt-get update --fix-missing
# Utility tools
RUN apt-get install -y vim htop net-tools psmisc wget curl git
# For suport set local time zone.
RUN export DEBIAN_FRONTEND=noninteractive && apt-get install tzdata -y
# Nginx
RUN apt-get install -y \
nginx \
libjpeg-dev \
zlib1g-dev \
libtiff5-dev \
libfreetype6-dev \
libwebp-dev \
python3 \
python3-pip \
libmemcached-dev \
python3-setuptools
RUN python3.6 -m pip install --user --upgrade pip setuptools wheel && rm -r /root/.cache/pip
RUN python3.6 -m pip install --timeout=3600 \
click \
termcolor \
colorlog \
pymysql \
Django==2.2.14 \
future \
captcha \
jinja2 \
django-statici18n \
django-post_office==3.3.0 \
django-webpack_loader \
gunicorn \
pymysql \
django-picklefield==2.1.1 \
openpyxl \
qrcode \
django-formtools \
django-simple-captcha \
djangorestframework==3.11.1 \
python-dateutil \
requests \
pillow \
pyjwt \
pycryptodome \
requests_oauthlib && \
# Scripts
COPY scripts_7.1 /scripts
COPY templates /templates
COPY services /services
RUN chmod u+x /scripts/*
RUN mkdir -p /etc/my_init.d && \
rm -f /etc/my_init.d/* && \
cp /scripts/create_data_links.sh /etc/my_init.d/01_create_data_links.sh
RUN mkdir -p /etc/service/nginx && \
rm -f /etc/nginx/sites-enabled/* /etc/nginx/conf.d/* && \
mv /services/nginx.conf /etc/nginx/nginx.conf && \
mv /services/nginx.sh /etc/service/nginx/run
# Seafile
WORKDIR /opt/seafile
ENV SEAFILE_VERSION=8.0.3 SEAFILE_SERVER=seafile-server
RUN mkdir -p /opt/seafile/ && cd /opt/seafile/ && \
wget https://github.com/haiwen/seafile-rpi/releases/download/v${SEAFILE_VERSION}/seafile-server-${SEAFILE_VERSION}-bionic-armv7.tar.gz && \
tar -zxvf seafile-server-${SEAFILE_VERSION}-bionic-armv7.tar.gz && \
rm -f seafile-server-${SEAFILE_VERSION}-bionic-armv7.tar.gz
# For using TLS connection to LDAP/AD server with docker-ce.
RUN find /opt/seafile/ \( -name "liblber-*" -o -name "libldap-*" -o -name "libldap_r*" -o -name "libsasl2.so*" \) -delete
EXPOSE 80
#CMD ["tail", "-f", "/dev/null" ]
CMD ["/sbin/my_init", "--", "/scripts/start.py"]
Only get into this if you have any experience generating seafile docker image as I’m using a modified version of the original https://github.com/haiwen/seafile-docker way of genarating the image.
( make server-rpi but modifing some paths and versions to hit 8.0.3 seafile version )
take into account that also avoiding an upgrade and creating an stack from scratch does not solve the problem.
stack file for 7.1.5:
version: '3.0'
db:
image: biarms/mysql:5.7.33-beta-circleci
- PUID=1000
- PGID=1000
- MYSQL_ROOT_PASSWORD=db_dev # Requested, set the root's password of MySQL service.
- MYSQL_LOG_CONSOLE=true
- /mnt/DISK/seafiles-mysql/db:/var/lib/mysql # Requested, specifies the path to MySQL data persistent store.
networks:
- seafile-net
deploy:
placement:
constraints:
- "node.hostname==rpi" #force to particular rpi node
resources:
limits:
memory: 500M
memcached:
image: memcached:1.5.6
entrypoint: memcached -m 256
networks:
- seafile-net
deploy:
placement:
constraints:
resources:
limits:
memory: 100M
seafile:
image: seafileltd/seafile-mc:7.1.5-rpi
- "80:80"
- "443:443" # If https is enabled, cancel the comment.
- /mnt/DISK/seafiles:/shared # Requested, specifies the path to Seafile data persistent store.
- DB_HOST=db
- DB_USER_HOST=db
- DB_ROOT_PASSWD=db_dev # Requested, the value shuold be root's password of MySQL service.
- TIME_ZONE=Etc/UTC # Optional, default is UTC. Should be uncomment and set to your local time zone.
- SEAFILE_SERVER_HOSTNAME=xxxxxxxx.duckdns.org # Specifies your host name if https is enabled.
- SEAFILE_ADMIN_EMAIL=xxxxxxxx@gmail.com # Specifies Seafile admin user, default is 'me@example.com'.
- SEAFILE_ADMIN_PASSWORD=xxxxxxxx # Specifies Seafile admin password, default is 'asecret'.
- SEAFILE_SERVER_LETSENCRYPT=true # Whether to use https or not.
networks:
- seafile-net
deploy:
placement:
constraints:
resources:
limits:
memory: 500M
networks:
seafile-net:
Stack for 8.0.3:
version: '3.0'
db:
- PUID=1000
- PGID=1000
networks:
- seafile-net
deploy:
placement:
constraints:
resources:
limits:
memory: 500M
memcached:
networks:
- seafile-net
deploy:
placement:
constraints:
resources:
limits:
memory: 100M
seafile:
image: seafileltd/seafile-mc:8.0.3-rpi
- "80:80"
- DB_HOST=db
- DB_USER_HOST=db
networks:
- seafile-net
deploy:
placement:
constraints:
resources:
limits:
memory: 500M
networks:
seafile-net:
take into account that some values have been replaced by xxxxx, also there are local DISK path references so these stack files will not work for you without some modifications.
