I am trying to setup Seafile Pro with Minio s3, but I keep running into memcache errors as follows:
seahub.log:
2018-12-01 11:56:24,751 [ERROR] django.pylibmc:146 set MemcachedError: error 47 from memcached_set: (0x55b74663ace0) SERVER HAS FAILED AND IS DISABLED UNTIL TIMED RETRY, host: 127.0.0.1:11211 -> libmemcached/connect.cc:720
File "/usr/local/lib/python2.7/dist-packages/django_pylibmc/memcached.py", line 140, in set
**COMPRESS_KWARGS)
ServerDown: error 47 from memcached_set: (0x55b74663ace0) SERVER HAS FAILED AND IS DISABLED UNTIL TIMED RETRY, host: 127.0.0.1:11211 -> libmemcached/connect.cc:720
seafile.log:
[12/01/2018 11:49:35 AM] ../common/s3-client.c(818): [S3] libcurl failed to put seafile-block-objects:ad1964aa773125063ba7929b8f6adf6d7f914670: Send failed since rewinding of the data stream failed.
[12/01/2018 11:55:40 AM] ../common/obj-cache.c(106): Failed to set bdfa66b7-c498-441a-b3a7-0ac13e4538cc-26b30cd1b906ac4982cfd348edc761aa0020d70c to memcached: SERVER HAS FAILED AND IS DISABLED UNTIL TIMED RETRY.
seafile.conf:
[commit_object_backend]
name = s3
bucket = seafile-commit-objects
key_id = xx
key = xx
host = ca.s3.example.com
use_https = true
path_style_request = true
memcached_options = --SERVER=127.0.0.1 --POOL-MIN=10 --POOL-MAX=100
[fs_object_backend]
name = s3
bucket = seafile-fs-objects
key_id = xx
key = xx
[block_backend]
name = s3
bucket = seafile-block-objects
key_id = xx
key = xx
seahub_settings.py:
# Memcached Options
CACHES = {
'default': {
# 'BACKEND': 'django.core.cache.backends.memcached.MemcachedCache',
'LOCATION': '127.0.0.1:11211',
'locmem': {
Any help would be appreciated,
Thanks
