Restore failing seaf-fsck.sh Segmentation fault
I have a lot of files in folder with repo id 5c060e2e-16c4-42bb-9c7d-aed4658bfbfc
When I upload some files there, the electricity was down. After that I tried to enter there and I couldn’t do that. I’ve tried to restore, but get segmentation fault
Seafile pro 13 in docker
./seaf-fsck.sh -r 5c060e2e-16c4-42bb-9c7d-aed4658bfbfc
Starting seaf-fsck, please wait ...
[2025-10-28 17:47:48] [INFO] ../../common/seaf-utils.c(128): Failed to read SEAFILE_MYSQL_DB_CCNET_DB_NAME, use ccnet_db by default[2025-10-28 17:47:48] [INFO] fsck.c(684): Running fsck for repo 5c060e2e-16c4-42bb-9c7d-aed4658bfbfc.[2025-10-28 17:47:48] [WARNING] Empty input for zlib, invalid.
[2025-10-28 17:47:48] [WARNING] ../../common/fs-mgr.c(2919): Failed to decompress fs object 33e64fea96fcf9f9f88fb54bad6005dab3800e33.
[2025-10-28 17:47:48] [INFO] fsck.c(68): Dir 33e64fea96fcf9f9f88fb54bad6005dab3800e33 is damaged.
[2025-10-28 17:47:48] [INFO] fsck.c(728): Repo 5c060e2e HEAD commit is damaged, need to restore to an old version.
[2025-10-28 17:47:48] [INFO] fsck.c(595): Scanning available commits...
[2025-10-28 17:47:48] [INFO] fsck.c(654): Find available commit e2f8bdce(created at 2025-10-27 17:41:31) for repo 5c060e2e.
[2025-10-28 17:47:48] [INFO] fsck.c(507): Checking file system integrity of repo Cloud(5c060e2e)..../seaf-fsck.sh: line 61: 112269 Segmentation fault      (core dumped) LD_LIBRARY_PATH=$SEAFILE_LD_LIBRARY_PATH ${seaf_fsck} -d "${default_seafile_data_dir}" -F "${default_conf_dir}" ${seaf_fsck_opts}
seaf-fsck run done
Done.
Please help me to restore my folder
Hello @insigmo ,
this issue should be a bug, we will fix it in next release.
Do you need something else’s. Core dump for example
That’s not necessary. This issue will be fixed in the next 13.0 version.
Ok, thanks a lot, I’m expecting
When can you fix it? I don’t have access to folder with 300GB
Can you try with the latest 13.0 version? It should have already been fixed.
Yep, I deleted all seafile images and pulled the last docker image, and I’ve got the same problem(
seafileltd/seafile-pro-mc:13.0.12 docker image id: 308006c4304e
[2025-12-27 13:49:41] [INFO] ../../common/seaf-utils.c(128): Failed to read SEAFILE_MYSQL_DB_CCNET_DB_NAME, use ccnet_db by default[2025-12-27 13:49:41] [INFO] fsck.c(684): Running fsck for repo 5c060e2e-16c4-42bb-9c7d-aed4658bfbfc.
[2025-12-27 13:49:41] [WARNING] Empty input for zlib, invalid.
[2025-12-27 13:49:41] [WARNING] ../../common/fs-mgr.c(2919): Failed to decompress fs object 33e64fea96fcf9f9f88fb54bad6005dab3800e33.
[2025-12-27 13:49:41] [INFO] fsck.c(68): Dir 33e64fea96fcf9f9f88fb54bad6005dab3800e33 is damaged.
[2025-12-27 13:49:41] [INFO] fsck.c(728): Repo 5c060e2e HEAD commit is damaged, need to restore to an old version.
[2025-12-27 13:49:41] [INFO] fsck.c(595): Scanning available commits...
[2025-12-27 13:49:41] [INFO] fsck.c(654): Find available commit e2f8bdce(created at 2025-10-27 17:41:31) for repo 5c060e2e.
[2025-12-27 13:49:41] [INFO] fsck.c(507): Checking file system integrity of repo Cloud(5c060e2e)...
./seaf-fsck.sh: line 61: 36958 Segmentation fault      (core dumped) LD_LIBRARY_PATH=$SEAFILE_LD_LIBRARY_PATH ${seaf_fsck} -d "${default_seafile_data_dir}" -F "${default_conf_dir}" ${seaf_fsck_opts}
seaf-fsck run done
Done.
Hello @insigmo ,
This issue was fixed starting from version 13.0.14. Please give it a try.
