I have seafile running in a docker container and nginx as a reverse proxy on the same server with ssl enabled. Another application running on that server is the radicale caldav… Furthermore, I have seafdav enabled.
Now, I want to change the path of seafile in the address, i.e. from
https://myexample.example.com/ to https://myexample.example.com/seafile.
Unfortunately, with the configuration it is not working.
This is the nginx file on the server:
server_name myexample.example.com;
location /radicale/ { #Der / am Ende ist wichtig!
proxy_pass https://localhost:5232/; #Der / am Ende ist wichtig!
proxy_set_header X-Script-Name /radicale;
proxy_pass_header Authorization;
location /seafile/ {
proxy_read_timeout 310s;
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_pass http://localhost:8001;
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/myexample.example.com-0001/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/myexample.example.com-0001/privkey.pem; # managed by Certbot
if ($host = myexample.example.com) {
} # managed by Certbot
listen 80;
return 404; # managed by Certbot
And this the nginx configuration in the docker container. I tried replacing location / with location /seafile but without success:
listen 80;
server_name myexample.example.com:8001;
client_max_body_size 10m;
proxy_pass http://127.0.0.1:8000/;
proxy_set_header Host $http_host:8001;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_request_buffering off;
location /notification/ping {
proxy_pass http://127.0.0.1:8083/ping;
access_log /var/log/nginx/notification.access.log seafileformat;
error_log /var/log/nginx/notification.error.log;
location /notification {
proxy_pass http://127.0.0.1:8083/;
location /seafdav {
proxy_pass http://127.0.0.1:8080;
proxy_read_timeout 1200s;
access_log /var/log/nginx/seafdav.access.log seafileformat;
The part of the docker-compose.yml:
seafile:
image: seafileltd/seafile-mc:11.0-latest
container_name: seafile
- "8001:80"
# - "443:443" # If https is enabled, cancel the comment.
- /opt/seafile-data:/shared # Required, specifies the path to Seafile data persistent store.
- DB_HOST=db
- DB_ROOT_PASSWD=db_dev # Required, the value should be root's password of MySQL service.
- TIME_ZONE=Etc/UTC # Optional, default is UTC. Should be uncomment and set to your local time zone.
- SEAFILE_ADMIN_EMAIL=me@example.com # Specifies Seafile admin user, default is 'me@example.com'.
- SEAFILE_ADMIN_PASSWORD=asecret # Specifies Seafile admin password, default is 'asecret'.
- SEAFILE_SERVER_HOSTNAME=myexample.example.com:8001 # Specifies your host name if https is enabled.
depends_on:
- db
- memcached
networks:
- seafile-net
This is the seahub_settings.py:
SECRET_KEY = "abc123"
SERVICE_URL = "http://myexample.example.com:8001"
CSRF_TRUSTED_ORIGINS = ["https://myexample.example.com"]
DATABASES = {
'default': {
'NAME': 'seahub_db',
'USER': 'seafile',
'PASSWORD': '123abc',
'HOST': 'db',
'PORT': '3306',
'OPTIONS': {'charset': 'utf8mb4'},
CACHES = {
'default': {
'LOCATION': 'memcached:11211',
'locmem': {
TIME_ZONE = 'Etc/UTC'
FILE_SERVER_ROOT = "http://myexample.example.com:8001/seafhttp"
And this the seafdav.conf:
[WEBDAV]
enabled = true
port = 8080
share_name = /seafdav
