I started using the go fileserver in our cluster with pro 9.0.7. The fileserver caused a high cpu load and memory usage, so I switched back to the old fileserver. Now I see, that in 9.0.8 there’s a fix in the go fileserver. Before I enable the fileserver again in the whole cluster, would it be possible to just enable it on one of the four nodes to see if the problem persists? Or will this produce problems in the database or elsewhere?
Thanks,
Dirk
