Hello. I wanna see what seadoc is, so i am trying to launch it on my sefile server running using docker. I’ve done all steps and modifications from manual including creating database and stuff.
I am still getting error when trying ot reach https://myserver.com/sdoc-server
{“error_msg”:“You don’t have permission to access.”}
Visiting https://myserver.com/sdoc-server directly is not supported yet. In a future version, a server version number will be returned instead of showing a permission error.
Okey so to be clear: if i can create, open and edit .sdoc file from seafile web interface → this means integration works?
What is the point of this feature? ))) Just a simple blank page with very poor editing options… or i misunderstand something? Documentaion says that its a wiki…
I am sorry. I’ve studied manual and i created the database sdoc_db, restarted containers but the error remains the same. I am a bit confused about DB_USER field in docker-compose, which user shall i specify? Manual says i need to grant privileges to seafile user, which i did.
MariaDB [(none)]> SHOW DATABASES;
| Database |
| ccnet_db |
| information_schema |
| mysql |
| performance_schema |
| sdoc_db |
| seafile_db |
| seahub_db |
7 rows in set (0.048 sec)
