Seadrive android client no libraries
Hello, I’m a new user. The install I have is on unraid, so I tried to follow their instructions first - everything except the android clients works perfectly. Both desktop apps work.
The issue I’m having on android (both 2.3.7 and 3) is that the app logs in but can’t see any libraries. It can create libraries just fine, it just can’t see them. After googling around I saw that some people had this issue too but there was no conclusive solution. What are my next steps?
Replying just because I tried the iphone app and it works perfectly. Is there really nobody here with any idea what this is about?
Buongiorno a tutti, anche a me è successo la stessa cosa. Con Android 12 le librerie non si vedono con iPhone funziona perfettamente. Qualche idea?
I have the same problem, the only way I found to make Seafile work is to downgrade to 2.3.4 using Aptoide (and then remembering to not upgrade it whenever I upgrade apps via Play Store…).
Thank you, solved it for me too.
