SeaDrive cached state Finder improvements
Loving SeaFile and SeaDrive is working really well for my org. Some issues around cache state, however, as currently there seems to be only 2 options presented based on file/folder context menu, and these don’t match the needed operations. Even a single unsynced file (which seems alarmingly common) makes removing existing downloads very tedious.
Basically, the options look like they follow the logic:
if any selected item is not downloaded:
  show "Download files"
else:
  show "Remove downloads"
But much more useful would be:
  show "Download missing files"
if any selected item is downloaded:
 show "Remove downloaded files"
And of course, please add the missing Keep Downloaded command (iCloud Drive for reference :slight_smile: ).
Thank you for you suggestions.
We’ll think about this suggestion.
We plan to add this feature in future version.
Starting from SeaDrive 3.0.23, we have added the “keep-downloaded” feature.
