We fixed the problem by uninstalling and reinstalling Kaspersky Endpoint. A fresh installation of Kaspersky did NOT produce any conflicts with Seadrive. Kaspersky and Seadrive now happily co-exist.
I have the same issue, but Kasperkshy is controlled by a central endpoint server and i can’t activate the option to trust seadrive.
I also reinstall Kaspersky, with no sucess.
Did you configure Kasperksy to trust seadrive ? Centrally ? On each device ? @pierre.baridon, do you have the same issue with a kasperksy endpoint server ?
Regards
Hi Gautier,
in our case, the only solution was the uninstall/install procedure.
Before, we had added Seadrive/Seafile Sync Client to trusted applications to no avail.
Regards
Ralf
Thank you ralf.
I did a fresh install of seadrive 0.91 on top of a reinstallation of Kaspersky, and the CPU usage / Crashes do not occur anymore. I’ll keep you informed if the problem reappears.
regards
Gautier
