Sure, but I don’t see an option to attach a file, so just some lines that I think are important. Some names are in Russian, if that causes some problems - I can replace them.
Problems started
[12/12/18 18:10:23] sync-mgr.c(2336): removing blocks for repo f55e67ba-81f1-447a-ab4e-01203a985c73
[12/12/18 18:10:23] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'uploading' to 'get sync info'.
[12/12/18 18:10:23] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'get sync info' to 'synchronized'.
[12/12/18 19:31:58] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\commits: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\commits”: No such file or directory.
[12/12/18 19:31:58] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\fs: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\fs”: No such file or directory.
[12/12/18 19:31:58] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\blocks: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\blocks”: No such file or directory.
[12/12/18 19:32:58] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\commits: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\commits”: No such file or directory.
[12/12/18 19:32:58] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\fs: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\fs”: No such file or directory.
[12/12/18 19:32:58] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\blocks: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\blocks”: No such file or directory.
[12/12/18 19:33:58] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\commits: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\commits”: No such file or directory.
[12/12/18 19:33:58] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\fs: Error opening directory “D:/Temp/SeaDriveTemp\deleted_storeSummary No such file or directory.
Later
[12/17/18 09:08:03] seadrive.c(684): Starting SeaDrive client 1.0.0
[12/17/18 09:08:03] seadrive.c(686): SeaDrive client source code version 79a313ca1e01a8370696edd5190d1ad3d8141e25
[12/17/18 09:08:04] repo-mgr.c(1731): Commit b0dc4fa8-9a91-4d7e-a786-1b812be99226/7a2e7a4e763aec0c58905140a18b5fc7264e01ea is missing
[12/17/18 09:08:05] repo-mgr.c(1731): Commit 6e267ce2-b2ba-4680-9793-0fe4ddb7ec86/833e2428511472394bcdedba5266e7835cc4904b is missing
[12/17/18 09:08:05] seafile-session.c(401): Moving commits for deleted repo 6e267ce2-b2ba-4680-9793-0fe4ddb7ec86.
[12/17/18 09:08:05] seadrive.c(709): rpc server started.
[12/17/18 09:08:05] seafile-session.c(401): Moving commits for deleted repo b0dc4fa8-9a91-4d7e-a786-1b812be99226.
[12/17/18 09:08:05] seafile-session.c(401): Moving fs for deleted repo 6e267ce2-b2ba-4680-9793-0fe4ddb7ec86.
[12/17/18 09:08:05] seadrive.c(729): Mount virtual drive as removable disk.
[12/17/18 09:08:05] seafile-session.c(401): Moving fs for deleted repo b0dc4fa8-9a91-4d7e-a786-1b812be99226.
[12/17/18 09:08:06] repo-mgr.c(1296): Removing store D:/Temp/SeaDriveTemp\deleted_store\commits\6e267ce2-b2ba-4680-9793-0fe4ddb7ec86
[12/17/18 09:08:06] repo-mgr.c(1296): Removing store D:/Temp/SeaDriveTemp\deleted_store\commits\b0dc4fa8-9a91-4d7e-a786-1b812be99226
[12/17/18 09:08:06] repo-mgr.c(1296): Removing store D:/Temp/SeaDriveTemp\deleted_store\fs\6e267ce2-b2ba-4680-9793-0fe4ddb7ec86
[12/17/18 09:08:06] repo-mgr.c(1296): Removing store D:/Temp/SeaDriveTemp\deleted_store\fs\b0dc4fa8-9a91-4d7e-a786-1b812be99226
[12/17/18 09:08:11] repo-mgr.c(2539): switching account to http://somewhere:8000 someone@somewhere.
[12/17/18 09:08:12] http-tx-mgr.c(1283): Bad response code for GET http://somewhere:8000/seafhttp/protocol-version: 404.
[12/17/18 09:08:12] fs-mgr.c(1181): [fs mgr] Failed to read dir 9bcc3f67de0a90b37c4bce5479c507df6791f2ca.
[12/17/18 09:08:12] repo-tree.c(177): Failed to get dir 9bcc3f67de0a90b37c4bce5479c507df6791f2ca from repo 9b1f9f55-cd2f-45b7-8cad-a6d2d631cde6.
[12/17/18 09:08:12] repo-tree.c(194): Failed to get dir 9bcc3f67de0a90b37c4bce5479c507df6791f2ca from repo 9b1f9f55-cd2f-45b7-8cad-a6d2d631cde6.
[12/17/18 09:08:12] repo-tree.c(194): Failed to get dir 56d4948a1f85b769523ce86225b279c7af32c52d from repo 9b1f9f55-cd2f-45b7-8cad-a6d2d631cde6.
[12/17/18 09:08:12] repo-tree.c(194): Failed to get dir ab974460f8a4d85a932a7fc544793f4b96c98905 from repo 9b1f9f55-cd2f-45b7-8cad-a6d2d631cde6.
[12/17/18 09:08:12] repo-mgr.c(1073): Failed to load tree for repo 9b1f9f55-cd2f-45b7-8cad-a6d2d631cde6.
[12/17/18 09:08:12] fs-mgr.c(1181): [fs mgr] Failed to read dir e723a361d1aff6c3ef37b3fa656c77041d7e113f.
[12/17/18 09:08:12] repo-tree.c(177): Failed to get dir e723a361d1aff6c3ef37b3fa656c77041d7e113f from repo f55e67ba-81f1-447a-ab4e-01203a985c73.
[12/17/18 09:08:12] repo-tree.c(194): Failed to get dir e723a361d1aff6c3ef37b3fa656c77041d7e113f from repo f55e67ba-81f1-447a-ab4e-01203a985c73.
[12/17/18 09:08:12] repo-mgr.c(1073): Failed to load tree for repo f55e67ba-81f1-447a-ab4e-01203a985c73.
[12/17/18 09:08:12] sync-mgr.c(1532): Cloning repo Install(b0dc4fa8-9a91-4d7e-a786-1b812be99226).
[12/17/18 09:08:12] sync-mgr.c(572): Repo 'Install' sync state transition from 'synchronized' to 'get token'.
[12/17/18 09:08:12] sync-mgr.c(1532): Cloning repo Старые файлы(6e267ce2-b2ba-4680-9793-0fe4ddb7ec86).
[12/17/18 09:08:12] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'synchronized' to 'get token'.
[12/17/18 09:08:12] [12/17/18 09:08:12] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'get token' to 'downloading'.
http-tx-mgr.c(4878): Download with HTTP sync protocol version 2.
[12/17/18 09:08:12] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'init') --> ('normal', 'check')
[12/17/18 09:08:12] sync-mgr.c(572): Repo 'Install' sync state transition from 'get token' to 'downloading'.
[12/17/18 09:08:12] http-tx-mgr.c(4878): Download with HTTP sync protocol version 2.
[12/17/18 09:08:12] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'init') --> ('normal', 'check')
[12/17/18 09:08:13] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'check') --> ('normal', 'commit')
[12/17/18 09:08:13] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'commit') --> ('normal', 'fs')
[12/17/18 09:08:13] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'check') --> ('normal', 'commit')
[12/17/18 09:08:13] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'commit') --> ('normal', 'fs')
[12/17/18 09:08:17] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'fs') --> ('finished', 'finished')
[12/17/18 09:08:17] sync-mgr.c(572): Repo 'Install' sync state transition from 'downloading' to 'load repo'.
[12/17/18 09:08:17] sync-mgr.c(572): Repo 'Install' sync state transition from 'load repo' to 'synchronized'.
[12/17/18 09:08:17] sync-mgr.c(572): Repo 'Install' sync state transition from 'synchronized' to 'committing'.
[12/17/18 09:08:17] sync-mgr.c(2564): All operations of repo Install(b0dc4fa8) have been processed.
[12/17/18 09:08:17] sync-mgr.c(572): Repo 'Install' sync state transition from 'committing' to 'synchronized'.
[12/17/18 09:10:05] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'fs') --> ('finished', 'finished')
[12/17/18 09:10:05] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'downloading' to 'load repo'.
[12/17/18 09:10:06] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'load repo' to 'synchronized'.
[12/17/18 09:10:07] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'synchronized' to 'committing'.
[12/17/18 09:10:07] sync-mgr.c(2564): All operations of repo Старые файлы(6e267ce2) have been processed.
[12/17/18 09:10:07] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'committing' to 'synchronized'.
[12/17/18 09:31:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\commits: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\commits”: No such file or directory.
[12/17/18 09:31:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\fs: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\fs”: No such file or directory.
[12/17/18 09:31:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\blocks: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\blocks”: No such file or directory.
[12/17/18 09:32:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\commits: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\commits”: No such file or directory.
[12/17/18 09:32:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\fs: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\fs”: No such file or directory.
[12/17/18 09:32:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\blocks: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\blocks”: No such file or directory.
[12/17/18 09:33:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\commits: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\commits”: No such file or directory.
[12/17/18 09:33:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\fs: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\fs”: No such file or directory.
[12/17/18 09:33:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\blocks: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\blocks”: No such file or directory.
[12/17/18 09:34:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\commits: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\commits”: No such file or directory.
[12/17/18 09:34:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\fs: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\fs”: No such file or directory.
[12/17/18 09:34:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\blocks: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\blocks”: No such file or directory.
[12/17/18 09:35:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\commits: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\commits”: No such file or directory.
[12/17/18 09:35:06] repo-mgr.c(1348): Failed to open store dir D:/Temp/SeaDriveTemp\deleted_store\fs: Error opening directory “D:/Temp/SeaDriveTemp\deleted_store\fs”: No such file or directory.
Logged off and then logged back on, no uninstall
[12/17/18 13:48:12] seadrive.c(684): Starting SeaDrive client 1.0.0
[12/17/18 13:48:12] seadrive.c(686): SeaDrive client source code version 79a313ca1e01a8370696edd5190d1ad3d8141e25
[12/17/18 13:48:15] seadrive.c(709): rpc server started.
[12/17/18 13:48:15] seadrive.c(729): Mount virtual drive as removable disk.
[12/17/18 13:48:17] repo-mgr.c(2539): switching account to http://somewhere:8000 someone@somewhere.
[12/17/18 13:48:18] http-tx-mgr.c(1283): Bad response code for GET http://somewhere:8000/seafhttp/protocol-version: 404.
[12/17/18 13:48:20] sync-mgr.c(1532): Cloning repo Install(b0dc4fa8-9a91-4d7e-a786-1b812be99226).
[12/17/18 13:48:20] sync-mgr.c(572): Repo 'Install' sync state transition from 'synchronized' to 'get token'.
[12/17/18 13:48:20] sync-mgr.c(1532): Cloning repo СДКиС(9b1f9f55-cd2f-45b7-8cad-a6d2d631cde6).
[12/17/18 13:48:20] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'synchronized' to 'get token'.
[12/17/18 13:48:20] sync-mgr.c(1532): Cloning repo Юристы(f55e67ba-81f1-447a-ab4e-01203a985c73).
[12/17/18 13:48:20] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'synchronized' to 'get token'.
[12/17/18 13:48:20] sync-mgr.c(1532): Cloning repo Старые файлы(6e267ce2-b2ba-4680-9793-0fe4ddb7ec86).
[12/17/18 13:48:20] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'synchronized' to 'get token'.
[12/17/18 13:48:20] sync-mgr.c(572): Repo 'Install' sync state transition from 'get token' to 'downloading'.
[12/17/18 13:48:20] http-tx-mgr.c(4878): Download with HTTP sync protocol version 2.
[12/17/18 13:48:20] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'init') --> ('normal', 'check')
[12/17/18 13:48:20] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'get token' to 'downloading'.
[12/17/18 13:48:20] http-tx-mgr.c(1186): Transfer repo 'f55e67ba': ('normal', 'init') --> ('normal', 'check')
[12/17/18 13:48:20] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'get token' to 'downloading'.
[12/17/18 13:48:20] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'init') --> ('normal', 'check')
[12/17/18 13:48:21] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'get token' to 'downloading'.
[12/17/18 13:48:21] http-tx-mgr.c(4878): Download with HTTP sync protocol version 2.
[12/17/18 13:48:21] http-tx-mgr.c(1186): Transfer repo '9b1f9f55': ('normal', 'init') --> ('normal', 'check')
[12/17/18 13:48:21] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'check') --> ('normal', 'commit')
[12/17/18 13:48:21] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'commit') --> ('normal', 'fs')
[12/17/18 13:48:21] http-tx-mgr.c(1186): Transfer repo 'f55e67ba': ('normal', 'check') --> ('normal', 'commit')
[12/17/18 13:48:21] http-tx-mgr.c(1186): Transfer repo 'f55e67ba': ('normal', 'commit') --> ('normal', 'fs')
[12/17/18 13:48:21] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'check') --> ('normal', 'commit')
[12/17/18 13:48:21] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'commit') --> ('normal', 'fs')
[12/17/18 13:48:21] http-tx-mgr.c(1186): Transfer repo '9b1f9f55': ('normal', 'check') --> ('normal', 'commit')
[12/17/18 13:48:21] http-tx-mgr.c(1186): Transfer repo '9b1f9f55': ('normal', 'commit') --> ('normal', 'fs')
[12/17/18 13:48:21] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'fs') --> ('finished', 'finished')
[12/17/18 13:48:22] sync-mgr.c(572): Repo 'Install' sync state transition from 'downloading' to 'load repo'.
[12/17/18 13:48:22] sync-mgr.c(572): Repo 'Install' sync state transition from 'load repo' to 'synchronized'.
[12/17/18 13:48:22] sync-mgr.c(572): Repo 'Install' sync state transition from 'synchronized' to 'committing'.
[12/17/18 13:48:22] sync-mgr.c(2564): All operations of repo Install(b0dc4fa8) have been processed.
[12/17/18 13:48:22] sync-mgr.c(572): Repo 'Install' sync state transition from 'committing' to 'synchronized'.
[12/17/18 13:48:22] http-tx-mgr.c(1186): Transfer repo '9b1f9f55': ('normal', 'fs') --> ('finished', 'finished')
[12/17/18 13:48:22] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'downloading' to 'load repo'.
[12/17/18 13:48:22] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'load repo' to 'synchronized'.
[12/17/18 13:48:23] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'synchronized' to 'committing'.
[12/17/18 13:48:23] sync-mgr.c(2564): All operations of repo СДКиС(9b1f9f55) have been processed.
[12/17/18 13:48:23] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'committing' to 'synchronized'.
[12/17/18 13:48:24] http-tx-mgr.c(1186): Transfer repo 'f55e67ba': ('normal', 'fs') --> ('finished', 'finished')
[12/17/18 13:48:24] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'downloading' to 'load repo'.
[12/17/18 13:48:24] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'load repo' to 'synchronized'.
[12/17/18 13:48:24] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'synchronized' to 'committing'.
[12/17/18 13:48:24] sync-mgr.c(2564): All operations of repo Юристы(f55e67ba) have been processed.
[12/17/18 13:48:24] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'committing' to 'synchronized'.
[12/17/18 13:48:30] repo-mgr.c(1487): Mark repo Юристы(f55e67ba) as deleted.
[12/17/18 13:48:30] repo-mgr.c(1487): Mark repo Install(b0dc4fa8) as deleted.
[12/17/18 13:48:30] repo-mgr.c(1487): Mark repo СДКиС(9b1f9f55) as deleted.
[12/17/18 13:48:31] repo-mgr.c(1566): Removing repo b0dc4fa8-9a91-4d7e-a786-1b812be99226 on disk.
[12/17/18 13:48:31] http-tx-mgr.c(4359): Bad response code for POST http://somewhere:8082/repo/6e267ce2-b2ba-4680-9793-0fe4ddb7ec86/pack-fs/: 403.
[12/17/18 13:48:31] http-tx-mgr.c(4916): Failed to get fs objects for repo 6e267ce2 on server http://somewhere:8082.
[12/17/18 13:48:31] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'fs') --> ('error', 'finished')
[12/17/18 13:48:31] sync-mgr.c(606): Repo 'Старые файлы' sync state transition from downloading to 'error': 'Error occured in download.'.
[12/17/18 13:48:31] dokan-ops.c(76): CreateFile \Shared with groups\Юристы: permission denied
[12/17/18 13:48:33] repo-mgr.c(1566): Removing repo 9b1f9f55-cd2f-45b7-8cad-a6d2d631cde6 on disk.
[12/17/18 13:48:33] dokan-ops.c(76): CreateFile \Shared with groups\Юристы: permission denied
[12/17/18 13:48:35] repo-mgr.c(1566): Removing repo f55e67ba-81f1-447a-ab4e-01203a985c73 on disk.
[12/17/18 13:48:35] dokan-ops.c(76): CreateFile \Shared with groups\Юристы: permission denied
[12/17/18 13:49:08] repo-mgr.c(2539): switching account to http://somewhere:8000 someone@somewhere.
[12/17/18 13:49:10] sync-mgr.c(1532): Cloning repo Старые файлы(6e267ce2-b2ba-4680-9793-0fe4ddb7ec86).
[12/17/18 13:49:10] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'synchronized' to 'get token'.
[12/17/18 13:49:10] sync-mgr.c(1532): Cloning repo Install(b0dc4fa8-9a91-4d7e-a786-1b812be99226).
[12/17/18 13:49:10] sync-mgr.c(572): Repo 'Install' sync state transition from 'synchronized' to 'get token'.
[12/17/18 13:49:10] sync-mgr.c(1532): Cloning repo СДКиС(9b1f9f55-cd2f-45b7-8cad-a6d2d631cde6).
[12/17/18 13:49:10] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'synchronized' to 'get token'.
[12/17/18 13:49:10] sync-mgr.c(1532): Cloning repo Юристы(f55e67ba-81f1-447a-ab4e-01203a985c73).
[12/17/18 13:49:10] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'synchronized' to 'get token'.
[12/17/18 13:49:10] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'get token' to 'downloading'.
[12/17/18 13:49:10] http-tx-mgr.c(4878): Download with HTTP sync protocol version 2.
[12/17/18 13:49:10] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'init') --> ('normal', 'check')
[12/17/18 13:49:10] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'get token' to 'downloading'.
[12/17/18 13:49:10] http-tx-mgr.c(1186): Transfer repo '9b1f9f55': ('normal', 'init') --> ('normal', 'check')
[12/17/18 13:49:10] sync-mgr.c(572): Repo 'Install' sync state transition from 'get token' to 'downloading'.
[12/17/18 13:49:10] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'init') --> ('normal', 'check')
[12/17/18 13:49:11] http-tx-mgr.c(4878): Download with HTTP sync protocol version 2.
[12/17/18 13:49:11] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'get token' to 'downloading'.
[12/17/18 13:49:11] http-tx-mgr.c(1186): Transfer repo 'f55e67ba': ('normal', 'init') --> ('normal', 'check')
[12/17/18 13:49:11] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'check') --> ('normal', 'commit')
[12/17/18 13:49:11] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'commit') --> ('normal', 'fs')
[12/17/18 13:49:11] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'check') --> ('normal', 'commit')
[12/17/18 13:49:11] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'commit') --> ('normal', 'fs')
[12/17/18 13:49:11] http-tx-mgr.c(1186): Transfer repo '9b1f9f55': ('normal', 'check') --> ('normal', 'commit')
[12/17/18 13:49:11] http-tx-mgr.c(1186): Transfer repo '9b1f9f55': ('normal', 'commit') --> ('normal', 'fs')
[12/17/18 13:49:11] http-tx-mgr.c(1186): Transfer repo 'f55e67ba': ('normal', 'check') --> ('normal', 'commit')
[12/17/18 13:49:11] http-tx-mgr.c(1186): Transfer repo 'f55e67ba': ('normal', 'commit') --> ('normal', 'fs')
[12/17/18 13:49:12] http-tx-mgr.c(1186): Transfer repo 'b0dc4fa8': ('normal', 'fs') --> ('finished', 'finished')
[12/17/18 13:49:12] sync-mgr.c(572): Repo 'Install' sync state transition from 'downloading' to 'load repo'.
[12/17/18 13:49:12] sync-mgr.c(572): Repo 'Install' sync state transition from 'load repo' to 'synchronized'.
[12/17/18 13:49:12] sync-mgr.c(572): Repo 'Install' sync state transition from 'synchronized' to 'committing'.
[12/17/18 13:49:12] sync-mgr.c(2564): All operations of repo Install(b0dc4fa8) have been processed.
[12/17/18 13:49:12] sync-mgr.c(572): Repo 'Install' sync state transition from 'committing' to 'synchronized'.
[12/17/18 13:49:12] http-tx-mgr.c(1186): Transfer repo '9b1f9f55': ('normal', 'fs') --> ('finished', 'finished')
[12/17/18 13:49:12] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'downloading' to 'load repo'.
[12/17/18 13:49:12] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'load repo' to 'synchronized'.
[12/17/18 13:49:13] http-tx-mgr.c(1186): Transfer repo 'f55e67ba': ('normal', 'fs') --> ('finished', 'finished')
[12/17/18 13:49:13] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'downloading' to 'load repo'.
[12/17/18 13:49:13] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'load repo' to 'synchronized'.
[12/17/18 13:49:13] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'synchronized' to 'committing'.
[12/17/18 13:49:13] sync-mgr.c(2564): All operations of repo СДКиС(9b1f9f55) have been processed.
[12/17/18 13:49:13] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'synchronized' to 'committing'.
[12/17/18 13:49:13] sync-mgr.c(2564): All operations of repo Юристы(f55e67ba) have been processed.
[12/17/18 13:49:13] sync-mgr.c(572): Repo 'СДКиС' sync state transition from 'committing' to 'synchronized'.
[12/17/18 13:49:13] sync-mgr.c(572): Repo 'Юристы' sync state transition from 'committing' to 'synchronized'.
[12/17/18 13:49:15] repo-mgr.c(1296): Removing store D:/SeaDriveTemp\deleted_store\commits\9b1f9f55-cd2f-45b7-8cad-a6d2d631cde6
[12/17/18 13:49:15] repo-mgr.c(1296): Removing store D:/SeaDriveTemp\deleted_store\commits\b0dc4fa8-9a91-4d7e-a786-1b812be99226
[12/17/18 13:49:15] repo-mgr.c(1296): Removing store D:/SeaDriveTemp\deleted_store\commits\f55e67ba-81f1-447a-ab4e-01203a985c73
[12/17/18 13:49:15] repo-mgr.c(1296): Removing store D:/SeaDriveTemp\deleted_store\fs\9b1f9f55-cd2f-45b7-8cad-a6d2d631cde6
[12/17/18 13:49:15] repo-mgr.c(1296): Removing store D:/SeaDriveTemp\deleted_store\fs\b0dc4fa8-9a91-4d7e-a786-1b812be99226
[12/17/18 13:49:15] repo-mgr.c(1296): Removing store D:/SeaDriveTemp\deleted_store\fs\f55e67ba-81f1-447a-ab4e-01203a985c73
[12/17/18 13:49:38] http-tx-mgr.c(1186): Transfer repo '6e267ce2': ('normal', 'fs') --> ('finished', 'finished')
[12/17/18 13:49:39] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'downloading' to 'load repo'.
[12/17/18 13:49:40] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'load repo' to 'synchronized'.
[12/17/18 13:49:40] sync-mgr.c(1417): All repo fs trees are loaded.
[12/17/18 13:49:40] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'synchronized' to 'committing'.
[12/17/18 13:49:40] sync-mgr.c(2564): All operations of repo Старые файлы(6e267ce2) have been processed.
[12/17/18 13:49:40] sync-mgr.c(572): Repo 'Старые файлы' sync state transition from 'committing' to 'synchronized'.
