we are running a Seafile cluster with haproxy. Our organization has a long and a short domain, what makes problems when users authenticate to seafile.myorganization.de and then open a link that points to seafile.myorg.de.
Now we configured haproxy to redirect all requests from the short to the long domain:
This perfectly works for webbrowser access and it also works with the Seafile client and the iOS and Android apps. Only the SeaDrive client (Windows) fails with the following errors:
[06/27/25 10:06:19] Starting SeaDrive client 3.0.15
[06/27/25 10:06:19] rpc server started.
[06/27/25 10:07:19] cache size limit is 10000000000
[06/27/25 10:09:25] adding account https://seafile.myorg.de:443 user@myorganization.de.
[06/27/25 10:09:26] Bad response code for GET https://seafile.myorg.de:443/api2/repos/: 301.
[06/27/25 10:09:26] Bad response code for GET https://seafile.myorg.de:443/seafhttp/protocol-version: 301.
You mentioned that the sync client can work — does that mean it can properly sync the library to the local machine and also upload files normally? (Not referring to the cloud file browser.)
Also, under normal circumstances, a 301 redirect should prevent the client from logging in, because the login request is a POST. After a 301 redirect, the request would be changed to a GET, which should cause login to fail.
Did you make any additional configurations to handle this? Or did you perform the redirect setup after logging in?
good, that you asked: the sync client doesn’t work, neither. I didn’t check the synchronization, before.
If I define a new account in the sync client using the short domain, and try to sync a library to a local folder, I’m getting the following error message:
[07/02/25 13:26:01] libcurl failed to POST https://seafile.myorg.de:443/seafhttp/repo/28bddbdd-5b09-4f74-9255-9aa5d4109ab2/pack-fs/: Send failed since rewinding of the data stream failed.
[07/02/25 13:26:01] Failed to get fs objects for repo 28bddbdd on server https://seafile.myorg.de:443.
[07/02/25 13:26:01] Transfer repo '28bddbdd': ('normal', 'fs') --> ('error', 'finished')
[07/02/25 13:26:01] Transition clone state for 28bddbdd from [fetch] to [error]: Unhandled http redirect from server. Please check server cofiguration.
It doesn’t matter, if I define “code 301” in the haproxy redirect statement. Without this, haproxy uses code 302, that doesn’t work, neither.
No, I can directly authenticate using the short domain. The account is registered as username@seafile.myorg.de. The sync client shows my remote libraries on the seafile server.
